Finding Total Capacitance with Electrical Breakdown
  • Thread starter Thread starter catie1981
    Capacitance
The problem involves a capacitor arrangement with given capacitances and a potential difference, focusing on the effects of electrical breakdown in one of the capacitors. The subject area is electrical circuits, specifically capacitance and charge calculations.
  • Participants discuss how to combine the capacitances, questioning the order of addition for capacitors in series and parallel. There are attempts to compute total capacitance and charge, with some participants expressing uncertainty about initial values and how to approach the problem.
The discussion is active, with participants exploring different approaches to calculate the total capacitance and charge. Some have made progress in understanding the relationships between the capacitors, while others are still seeking clarity on specific values and calculations.
Participants mention the challenge of determining the original charge on capacitor 1 and the implications of capacitor 3's breakdown. There is an indication of confusion regarding the setup and calculations, reflecting the complexity of the problem.
catie1981
In figure 25-29, a potential difference of V = 100 V is applied across a capacitor arrangement with capacitances C1 = 13.0 µF, C2 = 6.76 µF, and C3 = 4.14 µF. If capacitor 3 undergoes electrical breakdown so that it becomes equivalent to conducting wire, what is the increase in (a) the charge in microcoulombs on capacitor 1 and (b) the potential difference across capacitor 1?
http://img45.imageshack.us/img45/9895/fig2528iq2.gif
series capacitance 1/Ctotal= 1/C1 + 1/C2 + 1/C3
parallel capacitance Ctotal = C1 + C2 + C3
q= CV
well, I've tried many different ways- but I guess my biggest problem comes from not knowing whihc of the capacitors to add up first- meaning do I add together C1 and C2 first, or C2 and C3, or C1 and C3? If you add them up starting with those different pairs, the total capacitance comes to different values each time, so that could be a problem. After, that I might be abel to work it backwards to figure out the rest of the problem...I just can't get it off the ground...thanks
C1 and C2 form a parallel pair. Compute their total capacitance.
The parallel combination of c1 and c2 are in series with C3.
uh-oh...ok so I have that C123=3.42microFarad, which will also give q123=3.42e-4C...since C3 will be essentially taken out of the equation, I would need to figure out what the new total capctitance is without c3, right? Or did I miss something?
oooo, ok so I've got part (b)...which I got by simply dividing q123 by C12...however, how to get part (a)...that's the tricky part...I'm not really sure how to manipulate these numbers to determine q1 in the first place...
OK, so I now know where I'm having trouble...I don't know what the ORIGINAL value for q1 is, so if anyone can point me in the right direction to determine q1 before, maybe I can do q1 after...thanks
wooops, I got it solved...thanks anyway :)
how did you solve this first one?
14K
  • · Replies 19 ·
