Thread Closed
greatest value of the arg. of a complex number
Share Thread Thread Tools
Jun24-08, 04:54 PM   #1
Recognitions:
Homework Helper Homework Help
Given the complex number,u, is given by (7+4i)/(3-2i)
Express u in the form x+iy
Sketch the locus of z such that |z-u|=2
Find the greatest value of arg(z) for points on this locus
2. Relevant equations
For z=x+iy
[tex]|z|=\sqrt{x^2+y^2}[/tex]
[tex]arg(z)=tan^{-1}(\frac{y}{x})[/tex]
3. The attempt at a solution
First part is simply 1+2i
Second part for |z-u|=2, the locus is a circle with centre (1,2) and radius 2
third part with arg(z). Not too sure on how to find this.
I would assume the largest value for the circle is pi since it is a circle.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jun24-08, 10:57 PM   #2
Recognitions:
Can you picture the circle on the Argand diagram? If so, then you should be able to see at which point on the circle where z is a 'vector' from the origin of the circle to a point on the circumference, would result in the greatest angle arg(z).
EDIT: I think a better word to use, as Dick has said, would be "tangent". z is tangent to the circle.
Jun24-08, 10:59 PM   #3
Homework Helper 2012
Recognitions:
arg(z) is just the angle that a line through z and the origin makes with the x axis. The z that makes the maximum value of that angle must be the point of intersection with the circle of a line tangent to the circle starting at the origin. Seems to me a clever person could draw some right triangles and make a trig problem out of this.
Jun24-08, 11:25 PM   #4
Recognitions:
ok so I drew the circle, see the the real axis is a tangent to the circle at (2,0) and the Im(z) intersects the circle. So the largest arg(z) would be the tangent to the circle at the part where the circle intersects the axis?
EDIT: I think I got it out....
[itex]tan \alpha = 2[/itex] and [itex] sin \theta = \frac{2}{\sqrt{5}}[/itex]
and I need to find [itex]\alpha + \theta[/itex]
Jun24-08, 11:33 PM   #5
Recognitions:
The center of the circle is (1,2). It has radius 2. I don't think it's tangent to the real axis at (2,0). It's in your best interests to draw an accurate picture or you'll waste a lot of time. The z having largest arg(z) doesn't have to be on any axis. It isn't.
Jun24-08, 11:41 PM   #6
Recognitions:
Quote by rock.freak667 View Post
I think you are thinking along the right lines since you want to add two angles, but I have a problem believing everything you say.
Jun24-08, 11:44 PM   #7
Recognitions:
Quote by Dick View Post
But the real axis is a tangent at the point (1,0) right? Since the centre is (1,2) and if we go two units down (the length of the radius), it'll be (1,0) which is on the Re(z) right?
Jun24-08, 11:46 PM   #8
Recognitions:
Yes, it's (1,0) not (2,0). It's all trig now.
Jun24-08, 11:46 PM   #9
Recognitions:
ah thanks then
Thread Closed
Thread Tools
Similar Threads for: greatest value of the arg. of a complex number
Thread Forum Replies
Finding the greatest number in each row a matrix Programming & Comp Sci 3
Complex number Calculus & Beyond Homework 12
complex number Calculus & Beyond Homework 0
Complex Number Calculus & Beyond Homework 1
Complex Number, again... :( General Math 5
