Thread Closed
*sigh* volatage divider....?
Share Thread Thread Tools
Jul1-08, 01:07 AM   #1
I've been going over basic circuitry and got to the voltage divider. I don't understand the proof here:
http://en.wikipedia.org/wiki/Voltage...r#General_case
The first line makes sense. From Vi to Ground there are two resistors in series, so you add them, and V = IR and I is the same all around the whole circuit.
Then the 2nd line I don't get. Why is it R2 and not R1? I thought current would go From Vi through R1 and then to Vo, not Ground to Vo.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jul1-08, 03:28 AM   #2
Recognitions:
Homework Helper Homework Help
The potential difference across R2 (or Z2) is given by [itex]V_{out} - 0[/itex], where 0 is the ground voltage. For a resistor, V = IR so this means [itex]V_{out} - 0 = IR_2[/tex]
Jul1-08, 12:13 PM   #3
Let me see if I have this right.
Current goes from Vin through R1, which gives a voltage drop. Then since there is a branch, i.e. two things are in parallel, V across both is equal, but current probably isn't. So then you exploit the fact that at V at the branching point = Vout, and then you do this:
Quote by Defennder View Post
I think I got it. Thanks a lot. :D
Jul1-08, 07:58 PM   #4
Recognitions:
Actually there isn't any "branch" in between R1 and R2. In fact I would say that if there is a branch there, the voltage divider principle does not work. It works only if the circuit elements are connected in series, which they would not be if there was a branch in between.
Aug19-08, 10:15 PM   #5
Sorry to revive this. I'm back in "electronics" mode and still stuck on this damn problem again...
By branch I mean it branches off between R1 and R2 to Vout.
I guess my next question is how do they know Iin = Iout? Wouldn't it be Vin = I_in(R1 + R2) and Vout = Iout*R2? Why do they use the same value for I?
EDIT: Or are you assuming it's an open circuit, so that no current actually goes to the right into Vout? Then how would that work with a Load?
Aug19-08, 10:26 PM   #6
Recognitions:
The diagram is a little misleading. Vout does not denote a wire connected in between R1 and R2. It's just a line which indicates that the potential between the two resistors is V2. The same goes for Vin.
Iin = Iout is the assumption they make in order to derive the voltage divider principle. As said above, if that assumption is not true, ie. if there is a wire branching off from in between 2 resistors, then the potential divider principle does not work.
Quote by WarPhalange
EDIT: Yes you're right here. I don't know what you mean by "work with a load". It depends on whether you designate R2 as the load or something else.
Aug19-08, 10:28 PM   #7
Okay okay, that much makes sense. So how do you apply a voltage divider if you're not allowed to have anything between R1 and R2? I thought that was the whole point, where you kind of siphon off some of the current.
Aug19-08, 10:33 PM   #8
Recognitions:
The voltage divider principle is just a principle of circuits for easy evaluation of voltages across a circuit element, not a technique for getting a desired voltage out of something. To get a desired voltage across some complicated linear network, you first reduce it to it's Thevenin equivalent, then add resistors in the appropriate manner until you get the desired voltage.
Aug19-08, 10:38 PM   #9
I see... but if I had Rload at Vout >> R1 and R2, wouldn't that be approximately correct still?
So if I used a voltmeter I could still read Vout from in between R1 and R2, right?
I guess that's what confused me above all. I had thought this was something practical, not just a thought experiment type of thing.
Thread Closed
Thread Tools
Similar Threads for: *sigh* volatage divider....?
Thread Forum Replies
what is the formula to solve for RPM to volatage output in a generator Engineering, Comp Sci, & Technology Homework 2
Develop a Variable volatage divider.... Engineering, Comp Sci, & Technology Homework 2
pd (volatage)/ resistance Introductory Physics Homework 2
How do voltage-divider & current-divider work; physically? General Physics 2
::sigh:: What now? Differential Equations 7
