Why Is It Allowed to Drop Higher Order Terms in Lie Algebra Computations?
  • Context: Graduate
  • Thread starter Thread starter ledamage
    Lie algebras
The discussion centers around the justification for dropping higher order terms in computations involving infinitesimal generators in Lie algebra, particularly in the context of group properties and transformations. Participants explore the implications of linearizing group elements and the preservation of properties such as antisymmetry through these approximations.
  • One participant questions the validity of dropping terms of order \(\theta^2\) and higher, expressing concern about whether antisymmetry is preserved beyond first order.
  • Another participant suggests that the structure of the Lie algebra provides sufficient information about the group, implying that higher order terms do not affect the essential properties being examined.
  • A later reply identifies the Baker-Campbell-Hausdorff identity as relevant to the discussion, indicating that it allows for the use of first order expansions in calculations involving Lie groups.
  • One participant argues that properties satisfied to first order in generators will hold for the exponent, suggesting a general property of one-parameter subgroups.
  • Another participant shares their attempt to derive results using Taylor series, raising questions about the presence of factorial terms in the series expansion and the implications for their calculations.
  • One participant expresses satisfaction with the responses received, indicating their question has been answered.
Participants express differing views on the implications of dropping higher order terms, with some asserting that it is justified while others remain uncertain about the preservation of properties like antisymmetry. The discussion does not reach a consensus on these points.
Some participants note the importance of the Taylor series and the role of factorial terms in their derivations, highlighting potential limitations in the assumptions made during the discussion.
ledamage
Hey there!
I have a simple question concerning infinitesimal generators: In order to get properties of the group, one always linearizes the group element ([itex]g = \exp(\mathrm{i}\theta^a T^a) = 1 + \theta^a T^a + \hdots[/itex]); in this way, one can show, say, that the antisymmetric matrices (where both indices transform in the same representation given by the generators [itex]T^a[/itex]) form an invariant subspace by computing
[tex]\varphi_{ij} \to \varphi'_{ij} = \varphi_{ij} + {(\theta^a T^a)_i}^k {(\theta^a T^a)_j}^\ell \varphi_{k\ell} = \hdots[/tex]
Why is it allowed to drop all orders [itex]\theta^2[/itex] and higher during the computation? Wouldn't that mean that (in the above case) antisymmetry is preserved only to first order in [itex]\theta[/itex]? How do I know that antisymmetry is preserved in higher orders?
Hi
Well, you need a Lie algebra lecture book. I don't remember the name of the theorem. The basics is that the algebra of generators really tells you everything you need to know about the (connected to the unity part of the) group. The main reason is that, when you calculate the product of two elements of the group, each of them being represented by the exponential map in terms of generators, then the product can also be represented with a combination of generators in the exponential map. This is said terribly, but I hope this gives you a rough idea.
Another way : if [tex]A=e^{X}[/tex] and [tex]B=e^{Y}[/tex], then [tex]\log(AB)=X+Y+\frac{1}{2}[X,Y]+\cdots[/tex] where the dots can be calculated again in terms of commutators of [tex]X[/tex] and [tex]Y[/tex]. Applied to the representation of a Lie group in terms of exponential of its Lie algebra, you surely can see immediately why "the generators won't miss any element of the (connected to the unity part of the) group". I'm sure someone knows the name of this theorem. I could not find it on wiki easily, so I gave up.
You mean the Baker-Campbell-Hausdorff identity, right?
Yes, that's the name :smile:
That is the reason we can get away with only first order expansion or infinitesimal rotations in Lie groups to calculate full rotations : we will not "forget" along the way anything else than what is included in the generator's commutators. Does it make sens ?
Because any property satisfied to first order in the generators will hold for the exponent. This is a general property of all one-parameter subgroups such as those you've described. Look at the exponent this way:
[tex]e^{\lambda T}=(1+\frac{\lambda}{N}T)^{N}=(1+\delta\lambda T)^{N}[/tex]
for [tex]N\rightarrow\infty[/tex]
This makes explicit the fact that advancements along the orbit space of the group are given by N actions of [tex](1+\delta\lambda T)[/tex]. So an equation valid only for this linear operator will remain valid after N applications of this operator, that is, it remains valid for the exponentiation of the operator T. (you can see also that it is ONLY a property of exponentiated operators).
Okay, thanks to you all! My question is answered! :)
I trying to achieve the same derivation just with the definitions of taylor series, and stating but not proving the generator of [tex]\mbox{SO}(2)[/tex]
Beginning with the stipulation that we are dealing with elements of the identity connected component of a Lie Group, so that 1 always refers to the identity.
[tex]g(\theta)=\sum_{n=0}^\infty \frac{1}{n!}\partial^n_{\theta} g(a)(\theta-a)^n[/tex]
[tex]g(\theta)= g(a) + \sum_{n=1}^\infty \frac{1}{n!}\partial^n_{\theta} g(a) (\theta-a)^n[/tex]
So that, choosing infinitesimal changes around [tex]a=0[/tex]
[tex]g(\delta \theta)= g(0) + \sum_{n=1}^\infty \frac{1}{n!}\partial^n_{\theta} g(a)(\delta \theta)^n[/tex]
By convention, [tex]g(0)=1[/tex] refers to the identity as per the above stipulation
[tex]g(\delta \theta)= I + \sum_{n=1}^\infty \frac{1}{n!} \partial^n_{\theta} g(a) (\delta \theta)^n[/tex]
Now, for simplicity, dealing specifically with [tex]\mbox{SO}(2)[/tex] say, we can write and [tex]g \in \mbox{SO}(2)[/tex] as:
[tex]g(\theta) = e^{i \theta \tau}[/tex] where [tex]\tau = \sigma_y[/tex]
Or in summation,
[tex]g(\theta) = e^{i \theta \tau}=g(0) + \sum_{n=1}^\infty \frac{1}{n!}(i \theta \tau)^n[/tex]
So, infinitesimal changes
[tex]g(\delta \theta) = e^{i \delta \theta \tau}=g(0) + \sum_{n=1}^\infty \frac{1}{n!}(i \delta\theta \tau)^n[/tex]
Equating this with the expression with the above derivation, we get (along say [tex]n=1[/tex])
[tex]\tau = -i \partial_\theta g(0)[/tex]
Is this oh so very very wrong?
Just so you know, the reason why I am asking is because the n! is causing grief in the following form given for the element [tex]g(\delta \theta)[/tex]
[tex]g(\delta\theta) = 1 + i \sum^{n}_{i=1}\tau^i \delta\theta^i[/tex]
The issue I have with this is
a) He just stated that this is the form that [tex]g(\delta\theta)[/tex] takes
b) is there not an n! missing?
c) Should the i [tex](=\sqrt{-1})[/tex] not be brought and raised to the power i (index)
or can somebody justify this form of [tex]g(\delta \theta)[/tex]?
I mean if I used this and went on the same route as above to find the form of [tex]\tau[/tex], I wouldn't get the same answer. It would have an n! in it as the Taylor Series has one.
All this is answered by dropping all second order terms. A conclusion I didn't want to arrive at.
  • · Replies 27 ·
  • · Replies 40 ·
18K
  • · Replies 28 ·
