Finding velocity after displacement, and an angle
The discussion focuses on calculating the initial speed and launch angle of a golf ball that clears a 15m tree and lands 180m away from the tee. The initial speed is determined using the kinematic equation V² = Vi² + 2aΔx, resulting in an initial speed of 59.4 m/s. The launch angle is calculated using the tangent function, yielding an angle of 26.57 degrees. The importance of treating horizontal and vertical motions separately in projectile motion is emphasized, as well as the parabolic nature of the ball's flight path.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion concepts
  • Familiarity with trigonometric functions, specifically tangent and arctangent
  • Ability to analyze parabolic trajectories
  • Study the derivation and application of kinematic equations for projectile motion
  • Learn about the components of projectile motion and how to separate horizontal and vertical motions
  • Explore the concept of parabolic trajectories in physics
  • Investigate the effects of air resistance on projectile motion
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators seeking to enhance their teaching methods in these topics.
spacethisride
A driven golf ball just clears the top of a tree that is 15m in height, and 30 m from the tee. The ball then lands on the green 180m from the tee.
(a) What was the initial speed imparted to the golf ball?
(b) At what angle did the golf ball leave the tee?
(a) V2=Vi2 + 2aΔx
(a) V2=Vi2 + 2aΔx
0=Vi2 + 2(-9.8 m/s2)(180 m)
Vi2=3528
Vi=59.4 m/2
I feel like I might be missing something because I wasn't sure if the 9.8 was supposed to be negative or positive...
(b) tan X = 15m/30m
arctan(1/2) = X
X = 26.57 degrees
Can I make this assumption based on the information from the problem? The only thing I wasn't sure about was if I could make a straight hypotenuse from the starting point to the top of the 15m?
You should be able to do better than a straight line approximation.
What if you plotted the curve of the ball flight?
Since you know 3 points on this curve you should be able to describe it as a parabola.
Now what if you chose a smaller displacement from the tee in the x direction than just the tree? And if you kept choosing smaller and smaller displacements of x from the tee what might you call that initial line of flight? That angle would most surely be a better answer wouldn't it?.
Hi spacethisride,
(a) V2=Vi2 + 2aΔx
(a) V2=Vi2 + 2aΔx
Vi2=3528
Vi=59.4 m/2
The way you have used this equation is not quite right. You need to treat the horizontal and vertical motions separately. So for example, if you wanted to write this equation for the vertical motion, it would be:
[tex] v_{y}^2 = v_{0,y}^2 + 2 a_y (\Delta y)[/tex]
and similarly for the other kinematic equations. (Notice in the way you have written the equation, you have the vertical acceleration, and a horizontal displacement.)
(b) tan X = 15m/30m
arctan(1/2) = X
X = 26.57 degrees
No, it won't be a straight line. The particle follows a parabolic path; this means the particle must initially be aimed at a point above the tree, because it will fall away from the straight line path as it moves through the air.
  • · Replies 38 ·
  • · Replies 36 ·
