What is the Lagrangian for a Bead Sliding on a Cycloid-Shaped Circle?
  • Thread starter Thread starter kthouz
    Lagrangian System
The discussion focuses on deriving the Lagrangian for a bead sliding on a cycloid-shaped circle defined by the parametric equations x=a(B-sinB) and y=a(1+cosB) for 0<=B<=2pi. Participants suggest using polar coordinates to simplify calculations, emphasizing that the Lagrangian L can be expressed as L=T-V, where T is the kinetic energy (T=(1/2)mv^2) and V is the potential energy. The consensus is that while Cartesian coordinates can be used, polar coordinates may provide a more straightforward approach to describe the bead's motion effectively.
  • Understanding of Lagrangian mechanics
  • Familiarity with polar and Cartesian coordinate systems
  • Knowledge of kinetic and potential energy concepts
  • Basic proficiency in calculus for solving parametric equations
  • Study the derivation of the Lagrangian in polar coordinates
  • Explore applications of Lagrangian mechanics in different coordinate systems
  • Learn about the principles of conservation of energy in mechanical systems
  • Investigate the motion of particles on curves using parametric equations
Students of classical mechanics, physicists, and engineers interested in the dynamics of particles and the application of Lagrangian mechanics to complex motion scenarios.
kthouz
A bead slides without friction on a circle in the shape of cycloid with equations x=a(B-sinB) and y=a(1+cosB) where 0<=B<=2pi.
Find the lagrangian.
I've tried to solve that problem by converting the positions x and y from cartesian coordinate to a new system of coordiantes defined by those equations. The problem is that am having many long calcucaltions. My new idea is to work it out in the polar coordinates. Am i going in the roght way?
I'm a bit confused by your wording of the problem ("circle in the shape of a cycloid"), but I'm not sure you need to change coordinate systems; the lagrangian L=T-V should be straightforward to find in cartesian coordinates. T=(1/2)mv^2, etc...
Yes, I would use polar coordinates...the idea of the lagrangian is to compute an equation which can describe the motion of the particle (bead) anywhere that it could possibly be..since in this case it will always be somewhere on the outside of the circle the easiest way to describe its position is with r and theta.
  • · Replies 17 ·
  • · Replies 24 ·
