Another PDE question Where do I begin?
  • Thread starter Thread starter physmurf
    Pde
The discussion revolves around a problem in the context of partial differential equations (PDEs), specifically related to electrical circuits. The original poster is tasked with demonstrating that voltage and current functions satisfy the telegraph equation, given a system of equations that describe their relationship.
  • Exploratory, Assumption checking
  • The original poster expresses uncertainty about how to begin solving the problem and considers the possibility of using a change of variables. They seek suggestions for a course of action.
  • One participant suggests taking partial derivatives of the provided equations to explore potential combinations that could lead to the desired result.
  • Another participant questions the validity of assuming the equality of mixed partial derivatives, prompting a clarification about the conditions under which this assumption holds.
The discussion is ongoing, with participants exploring different approaches to tackle the problem. Some guidance has been offered regarding the use of partial derivatives, and there is an active inquiry into the assumptions related to mixed derivatives.
The original poster indicates a lack of clarity on how to initiate the problem-solving process, which may reflect constraints in their understanding of the underlying concepts or methods related to PDEs.
physmurf
Consider an electrical cable running along the x-axis which is not well insulated from ground, so that leakage occurs along its entire length. Let V(x,t) and I(x,t) denote the voltage and current at point x in the wire at time t. These functions are related to each other by the system
[tex]\frac{\partial V}{\partial x}=-L \ \frac{\partial I}{\partial t}- RI, \ and \ \frac{\partial I}{\partial x}=-C\\\frac{\partial V}{\partial t}-GV[/tex]
where L is the inductance, R is the resistance, C is the capacitance, and G is the leakage to ground. Show that V and I each satisfy
[tex]\frac{\partial^{2}u }{\partial x^{2}}=LC\frac{\partial^{2} u }{\partial t^{2}}+(RC+LG)\frac{\partial u }{\partial t}+RGu[/tex]
which is called the telegraph equation.
I am not sure of even where to start. Initially I would think a change in variable might do it, but then again, I don't know what change in variable to use. Any suggested course of action?
Thanks.
Try taking partial derivatives of the equations above.. for instance try taking the partial derivative with respect to x of the first equation and then look at the other equation and see what you might want to take a partial derivative of that so that you can combine the equations.
Is it always safe to assume that
[tex]\frac{\partial^{2}I}{\partial x \partial t}=\frac{\partial^{2}I}{\partial t \partial x}[/tex]
It is okay as long as the mixed derivatives are continuous.
