Help with Burning Balsa Wood Green Using Copper
  • Thread starter Thread starter Applemush
    Copper
To achieve green flames when burning balsa wood, using copper compounds is essential, as elemental copper does not dissolve in water. The discussion suggests utilizing copper chloride, a soluble copper compound, to create a solution that can be absorbed by the balsa wood. This method is preferred over attempting to dissolve copper directly, which is ineffective. The key takeaway is to focus on soluble copper compounds for successful results.
  • Understanding of copper compounds, specifically copper chloride.
  • Basic knowledge of wood combustion and flame chemistry.
  • Familiarity with safe handling of chemical solutions.
  • Experience with soaking and preparing wood for burning.
  • Research the properties and preparation methods of copper chloride solutions.
  • Explore safe techniques for soaking balsa wood in chemical solutions.
  • Investigate other metal salts that produce colored flames when burned.
  • Learn about the combustion process and how different materials affect flame color.
Woodworkers, hobbyists interested in pyrotechnics, and anyone experimenting with flame effects in woodworking projects.
Applemush
Hi, I'm trying to get balsa wood to burn green, and I know that copper burns green. If i cut up pieces of copper and dissolve them in water, then let the balsa wood soak up the water, I imagine it would burn green. However, I don't know if I can dissolve copper in water. I would appreciate any comments or suggestions on what I'm doing. Thank you.
-Sincerly
Applemush.
Chemistry news on Phys.org
Well, I know that you can't dissolve copper in water, but would cutting copper up into tiny pieces and placing them in water create a copper solution. And if that won't do, how can i create a copper solution.
Start with some copper compound, not copper itself. Copper chloride for example.
12K
  • · Replies 22 ·
12K
