Slower rotation curves at centre
  • Context: Graduate
  • Thread starter Thread starter Zman
    Curves Rotation
The discussion revolves around the behavior of galaxy rotation curves, specifically the observation that rotation velocities of stars or gas decrease towards the center of galaxies, contrary to predictions from Kepler's laws. Participants explore the implications of mass distribution and the role of dark matter in shaping these curves.
  • One participant notes that rotation velocities should be highest just outside the center according to Kepler’s third law, but observes a drop in velocity towards the center.
  • Another participant explains that galactic rotation curves are influenced by mass distribution, suggesting that dark matter in galactic halos contributes to the observed velocity profiles.
  • A question is raised about the validity of calculating inner mass using Kepler’s laws when considering the outer mass distribution, particularly near the galaxy's center.
  • Further clarification is provided regarding the measurement of rotation velocity and the calculation of mass within orbits, emphasizing the importance of considering non-spherical mass distributions in real galaxies.
Participants express differing views on the implications of mass distribution for rotation curves, with some agreeing on the role of dark matter while others question the methods used to calculate mass near the center of galaxies. The discussion remains unresolved regarding the validity of certain assumptions in the calculations.
There are limitations in the assumptions made about mass distribution, particularly regarding spherical symmetry and the treatment of outer mass when calculating rotation velocities. These factors contribute to the complexity of the discussion.
Zman
On galaxy rotation curves, the velocities of stars (or gas) rotating about their galactic centre remain fairly constant as the distance from the galactic centre increases.
But these rotation curves show a drop in rotation velocity towards the centre of the galaxy.
http://astro.berkeley.edu/~mwhite/darkmatter/rotcurve.html"
I accept that at the centre the rotation velocity must be zero but just out from the centre, Kepler’s third law predicts that the velocities should be greatest and then fall off with increasing distance.
Does this velocity profile exist because the centre of galaxies up to about 6kpc (in the hyperlinked curve) are a bit like a solid mass?
Astronomy news on Phys.org
Galactic rotation curves are determined by the distribution of mass throughout the galaxy.
Kepler's laws were derived empirically for the solar system where nearly all the mass is in the centre, in the Sun.
To obtain the typical galactic rotation curve, where for a large proportion of the radial distance the rotation velocity remains fairly constant, you need a lot of mass outside the visible galactic disk. This is one of the reasons it is believed galactic haloes contain a lot of Dark Matter.
As the radius approaches the centre you are leaving more and more mass outside that radius and the rotational velocity drops off, however often very near the centre it often starts to increase again indicating that there is often a large mass at the centre itself, most probably a massive Black Hole.
I hope this helps.
Garth
Hi Garth,
When the mass of a galaxy is worked out from the centre to a given radius r, the velocity of rotation is determined at that radius. Then using Kepler’s 3rd law, the inner mass can be determined. The outer mass (beyond the radius r) seems to be ignored.
Are you saying that near the centre of a galaxy where there is a higher density of mass that the above method is not valid?
Well, first it is the rotation velocity that is measured, using the slope of the red shift across the galactic disc as presented (projected) onto our celestial sphere.
Then the mass within that orbit can be calculated. If the outer mass is spherically distributed, symmetrically about the galactic centre the contributions from opposite sectors cancel themselves out and they can be ignored.
However, if they are not spherically distributed then they have to be taken into account, this is the case with real galaxies.
The actual Galaxy rotation curve is the data on which a model of the mass distribution has to be constructed.
Garth
  • · Replies 19 ·
  • · Replies 72 ·
12K
