Thread Closed
Hydrogen Fuel Cells
Share Thread Thread Tools
May10-04, 04:25 PM   #1
Hydrogen Fuel Cells
Does anyone have any hands on expierence with Hydrogen fuel cells used as the backup source on UPSs.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
May10-04, 04:30 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
I have plenty of experience with fuel cells, but not particularly as a backup for a UPS. Do you have a specific question?
- Warren
May11-04, 08:00 AM   #3
Are there specific fire codes that have to be met for a US installation?
Do the fuel cells go bad?
What Kind of heat load do they generate?
What is the product of the chemical reaction, and do the cells have to be placed in a well ventilated area?
What is your experience and what are the pos and neg of fuel cells?
How do Wet Cells and Fuel cells compare to each other?
What maintenance do the fuel cells require?
What temperature range do they need to kept in.
How does temperature effect their discharge or does it?
I read a interesting article about a large UPS manufacturer and a fuel cell manufacturer collaborating to use fuel cell technology for rack mounted ups's.
Jason
May11-04, 04:46 PM   #4
Recognitions:
Hydrogen Fuel Cells
Quote by jtweedie@atdesk.com
I don't know, I'm not a civil engineer.
I'll assume we're discussing only proton-exchange membrance cells from now on. Yes, they can go bad, if the membrane is allowed to dry out, or if liquid water is injected into the cell.
Fuel cells are roughly 50-60% efficient.
The only chemicals produced are pure water. On the other hand, some hydrogen can sneak out even from recirculating setups, so yes, you need hydrogen sensors and a good ventilation system.
Pro: efficiency.
Cons: dangerous reactants, cost, complexity of apparatus.
A wet cell is an ordinary Energizer battery. I don't think I really need to describe the difference.
Ideally, none. In reality, it's probably the supporting apparatus that will need the most maintenance.
Most cells operate at about the 90 degree celsius mark.
That's a complex question; the effect depends quite a bit on the geometry and design.
- Warren
Thread Closed
Thread Tools
Similar Threads for: Hydrogen Fuel Cells
Thread Forum Replies
Fuel cells:electricity or hydrogen powered General Engineering 39
Hydrogen fuel cells! Materials & Chemical Engineering 2
fuel cells General Engineering 7
Questions on fuel cells General Engineering 16
fuel cells General Engineering 14
