Kalman Filters: Understanding Kalman Recursion and AR(1) Process
  • Thread starter Thread starter mr.t
    Recursion
This discussion focuses on the application of Kalman filters in signal processing, specifically using the AR(1) process defined by x(n) = 0.5x(n-1) + w(n) with white noise variance of 0.64. The state-space model is established with the equations x(n) and y(n) = x(n) + v(n), where v(n) has a variance of 1. Key formulas for Kalman recursion are provided, including the calculations for the Kalman gain K(n) and the estimation error covariance P(n|n). The discussion also addresses the confusion regarding the measurement covariance "I" and the relationship between the iterative approach and the Riccati equation for calculating the Kalman gain.
  • Understanding of state-space models in control theory
  • Familiarity with Kalman filter algorithms and their mathematical foundations
  • Knowledge of AR(1) processes and their characteristics
  • Basic proficiency in matrix operations and linear algebra
  • Study the derivation and application of the Riccati equation in Kalman filtering
  • Learn about the implementation of Kalman filters in Python using libraries like NumPy and SciPy
  • Explore advanced topics in state estimation and filtering techniques
  • Review online tutorials and resources specifically focused on Kalman filters, such as those on Coursera or edX
Signal processing engineers, control system designers, and data scientists interested in state estimation and filtering techniques will benefit from this discussion.
mr.t
As this is concerning signal processing i guess this is the right place to post the question. I am Trying to learn how to use kalman filters. I've reached some form of verry basic understanding of the state-space model but I am still kindof confused. What I am trying to do now is to understand an example that is using kalman recursion to find the steady state kalman gain.
We have an AR(1) process described by: x(n) = 0.5x(n-1) + w(n), where w(n) is white-noise with variance 0.64. we are observing a process: y(n) = x(n)+ v(n), where v(n) is white-noise with variance 1.
The state-space model becomes:
y(n) = x(n) + v(n)
and we see that A(n-1) = 0.5, B(n) = 1 and C(n) = 1. From the variances we have Qw=0.64 and Qv=1.
We have the initial conditions: x'(0|0) = 0 and E{e^2(0|0)} = 1, where e(0|0) = x(0) - x'(0|0). (' = estimate) and I am trying to use these formulas to perform the recursion: (im skipping some matrix-related stuff since the matrices in this example is just single numbers so transposing isn't doing anything)
x'(n|n-1) = Ax'(n-1|n-1)
P(n|n-1) = AP(n-1|n-1)A + Qw
K(n) = P(n|n-1)C[CP(n|n-1)C+Qv]^-1
x'(n|n) = x'(n|n-1) + K(n)[y(n) - Cx'(n|n-1)]
P(n|n) = [I-K(n)C]P(n|n-1)
We start with P(0|0) = E{e^2(0|0)} = 1.
Ok. Now to my problem. How do i get y(n) ? I get stuck on the first iteration when I want to calculate x'(1|1) and i need y(1), how to i get it?
what is I ? on the last formula-row "P(n|n) = [I-K(n)C]P(n|n-1)"? In the example it is equal to 1, but
where do the 1 come from?
Also if anyone have any good (simple!) tutorial suggestion on the net about kalman-filtering that would be appreciated.
Thanks a lot!
Ok my bad. Seems like you don't even calculate x(n|n|) in the recursion, you just calculate P(n|n-1), K(n) and P(n|n) for each step (!). But this leads to another question.
When you have done your iterations and found that your P:s and K:s are getting steady, they you have your Kalman gain as the steady K(n). But there is another formula of calculating K (pretty much the same, but apart from the iteration-formulas in my textmaterial) as in:
[tex]K = PC^{T}(CPC^{T} + Q_{v})^{-1}[/tex]
Is said to give the corresponding Kalman gain for the Riccati-equation:
[tex]P = APA^{T} + Q_{w} - APC^{T}[CPC^{T} + Q_{v}]^{-1}CPA^{T}[/tex]
Whats the deal with this Riccati-equation? can't you just use the iterations to find both P and your Gain at the same time?
  • · Replies 20 ·
