Fix Unbootable Hard Drive - Get Help Now!
  • Thread starter Thread starter Mc.
    Drive Hard
The discussion revolves around troubleshooting an unbootable hard drive in a personal computer, with a focus on identifying potential hardware issues and recovery options for important data. Participants explore various diagnostic approaches and recovery methods, including software utilities and hardware checks.
  • One participant describes the issue as a "boot system failure" and notes that the system indicates no hard drive is installed.
  • Another suggests using a live CD of Ubuntu to check if the hard drive is recognized and to back up data if possible.
  • Some participants propose that the hard drive may have dying sectors, recommending the purchase of a new hard drive for data recovery.
  • There is a suggestion to check BIOS settings to see if the hard drive is detected, as a lack of detection could indicate a hardware failure or cable issue.
  • One participant mentions using utilities like BartPE or running a chkdsk command to address potential bad sectors on the drive.
  • Another participant raises the possibility of a damaged boot sector or a mechanical failure of the hard drive, suggesting professional data recovery services as a last resort.
  • One participant shares a personal experience with a mechanical failure after a drop, emphasizing the importance of data backups.
  • There is a discussion about ensuring the hard drive jumper settings are correct and the implications of switching hard drives between systems.
Participants express various hypotheses about the cause of the issue, including potential hardware failures and BIOS configuration problems. There is no consensus on the exact cause or the best course of action, as multiple competing views remain throughout the discussion.
Participants note the importance of checking BIOS settings and jumper configurations, but there are unresolved questions about the specific nature of the hard drive failure and the effectiveness of suggested recovery methods.
Mc.
Hi guys
I need help with my pc I use for my projects and programming.It doesn't want to boot from the hard drive and really need it to because I have some very important information in it. I am not good with hardware(hope one day i will) but have tried everything I can to get it working again. So please guy, anyone who can help unleash this matter please help me.
Any help is really appreciated
Mc.
Computer science news on Phys.org
Can you give us some info on what happens when you turn it on? "It doesn't boot" doesn't help us much.
Hey thanks for the interest.
When I switch it on it says "boot system failer insert disk and press enter" and when I do that it continues to load windows setup and then it says there is no hard drive installed.
Mc.
I'd get myself a live cd of UBUNTU (www.ubuntu.com) and boot off of that. from there you just go to PLACES>>Computer and see if the drive was found. you can then burn all of your info to cd from there.
Sounds like dieing sectors to me. Is your computer a Dell or Gateway by any chance? The easiest fix will be to go out and buy another HD and after installing it and reloading your OS, plug in your old one as a secondary to retrieve your data.
cds are a lot cheaper than harddrives... another check is to see if it is a hardware problem. Does you BIOS detect the drive, because if it doesn't than the above 2 ideas are pointless. check this by hitting <del> or <F2> right at startup and go to the corresponding menu for IDE or SATA HDD detection. If it doesn't detect it it could be that the harddrive is completely crapped out, or it could be the cable or the motherboard channel, or the power.
Another thing you might try is to download a utility like BartPE or get a boot floppy or CD and run a chkdsk /f on the drive. I've come across quite a few drives that woudn't boot because of a couple bad sectors on the disk.
Mc.
One should always make a bootable rescue disk (CD, these days, as opposed to 3.5'' floppy). That way one can boot off something other than the HD.
It could be that the boot sector is damaged.
However, if the system cannot read the HD, then is could be the controller on the motherboard is bad, or it could be a catastrophic hard-drive failure, i.e. a mechanical failure. A mechanical failure of the HD means you'll have to have to send it to a company that does data recovery from failed HD's and that will cost ~$1500-$2000, and success is not necessarily guaranteed.
However, what one can do is buy an HD caddy with USB connectivity and put the HD in that to see if can be read on another computer.
My daughter's laptop drop off a stool and the HD crashed. It appears to be a mechanical failure such that it could not be read. The only recourse was to install a new HD in her laptop and install a fresh copy of Windows from the Windows CD that came with the laptop.
The guy who worked on the laptop told me that his company is seeing much higher failure rates of HD of with 200 GB or more, especially those using NTFS.
If one values one's work, one should backup all data files on DVD and one or more external HD's which are protected from vibration and temperature variations.
Thanks again.
Honestly these ideas help. But to tell what really happened: my friend came with his HDD and we removed mine to put his.We then did what he wanted (writting his info to a disk) and then when I tried to put mine there came a problem.what I trying to say is,the chances of it being a HDD mechanical failer are slim. i thought maybe its some BIOS configuration that change.
Mc.
Check to make sure that your jumper is set to master on the HDD and some mobo's are picky about the boot drive being on IDE0 (The first wide ribbon cable connector).
Hmm - hopefully you changed HDD's with the computer off. Is it a laptop or desktop?
Switching out HD's is not a good idea, especially if the friends HD was setup on a different OS or motherboard. Next-time but the other HD in a USB caddy.
Settings might have changed.
When starting up the PC, go into set up (some BIOS use del key, others F8, F10 or F12, which one holds down) and look at the boot sequence. See if the setup can detect the HD. If you don't feel comfortable doing this, take the computer to a reputable computer service or Best Buy's Geek Squad, and explain the problem.
Sometimes devices get switch if one is exchanged. One might have to uninstall components like CD.
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 30 ·
