Length of Line from 90° Angle in 3-4-5 Triangle
  • Thread starter Thread starter kenewbie
    Triangle
The problem involves determining the length of a line extending from the 90-degree angle of a 3-4-5 triangle to the midpoint of the hypotenuse. The context suggests a focus on geometric properties rather than trigonometric methods.
  • Exploratory, Assumption checking
  • Participants discuss the possibility of using basic geometric properties to find the length, with one participant expressing confusion about forming right triangles with known lengths. Others suggest using the cosine rule, which the original poster initially wanted to avoid.
Some participants have explored different methods, including the cosine rule and the Pythagorean theorem. There is a recognition of a misunderstanding regarding the problem setup, with one participant clarifying their interpretation of the line's position.
There is an emphasis on avoiding trigonometric solutions, and some participants express uncertainty about the problem's requirements and their interpretations of the line's placement.
kenewbie
In a 3-4-5 triangle, how long is a line extending from the 90 degree angle down to the middle of the hypothenus.
Thats all I've been given. I think I am supposed to figure this out without trig, just basic geometric properties. But I'm stumped.
I can see that the hypothenus is divided into two 2.5 halves, but I can't seem to make any right angle triangles where I know two lengths.
k
Use the cosine rule.
I wanted a solution without trig.
But I just figured it out. A 90 degree angle has to be located on a circle with diameter equal to the hypothenus, and so the line must be equal to the radius of the circle, and so it is 2.5
k
k
Your answer is correct.
You could have also just used Pythagorean theorem and a system of equations with 2 variables to work it out.
Never mind my last post. I read the problem incorrectly. I thought the line was perpendicular to the hypotenuse, not at its midpoint.
  • · Replies 59 ·
232K
