| Thread Closed |
how to make a glass out of a bottle |
Share Thread | Thread Tools |
| Sep2-08, 05:51 PM | #1 |
using only
a bottle and a rope and a water soure |
| Sep3-08, 05:56 AM | #2 |
| Sep3-08, 03:14 PM | #3 |
no a class for contaning liquides
| Sep3-08, 04:16 PM | #4 |
What's the bottle made out of? Can the water "source" be steam? Or ice, for that matter? Can I close the bottle? Actually, can I open it? How much rope is there? Is the rope thin enough to fit through the opening of the bottle, assuming there's one-and-only-one opening in the bottle? If the bottle isn't already made out of glass, I think the answer is pretty definitively "no", unless there are some other ingredients (like sand at least). Is there a time limit for how long it takes, or can it take 1000 years and still be acceptable?
DaveE |
| Sep3-08, 08:18 PM | #5 |
Mentor
Besides, topologically speaking they already are the same shape .
| Sep4-08, 03:57 PM | #6 |
a glass bottle like a wine bottle
with a narrow opening we need to convert it to a drinking cup using a rope (as long as you want) and a water source this proccess took at most 10 minutes |
| Sep4-08, 04:47 PM | #7 |
If I can use alcool too, I tie the rope around the bottle and soak it with alcool. Then I put water in the bottle until the level of the rope.
Igniting the rope the outside of the bottle will expand. The water dissipates the heat maintaining the form in the inside of the bottle. The stress will cut the bottle neatly, making a drinking glass. |
| Sep4-08, 05:01 PM | #8 |
You could probably even do it with NO rope, and just using water, since the difference in temperature between nearly-freezing water and boiling water is (I believe) sufficient to break glass. DaveE |
| Sep4-08, 08:05 PM | #9 |
| Sep4-08, 10:50 PM | #10 |
you are correct that its a string
this srting is a thin rope substance(like hemp rope) no alcohol and we have only cold water in the end we get get a clean cut of the bottle |
| Sep5-08, 04:30 PM | #11 |
1st clue:
the water splits the glass |
| Sep5-08, 05:18 PM | #12 |
Soak the string. Tie it tightly around the bottle. Let it dry? It will shrink.
I just doubt that you'll avoid shattering the bottle. And I assume we don't have to concern ourselves with a razor-sharp edge? |
| Sep5-08, 05:22 PM | #13 |
you are close to the truth but you are not correct
we get a lean cut |
| Sep6-08, 12:22 AM | #14 |
| Sep6-08, 09:38 AM | #15 |
Spoiler
you tie a loop around the bottle at the place you want to cut it and two people move it back and forward thus creating local heat from the friktion on the place of the rope then we pore water on that bottle and because of the heat differences the glass splits clean |
| Sep8-08, 12:47 PM | #16 |
I've noticed a lot of the brain teasers here aren't really brain teasers or riddles but more of "what would McGyver do" kind of questions.
| Thread Closed |
| Thread Tools | |
Similar Threads for: how to make a glass out of a bottle
| How do you make a bologna bottle? | Materials & Chemical Engineering | 2 | ||
| breaking a glass soda bottle | Introductory Physics Homework | 6 | ||
| pressure in a glass bottle | Introductory Physics Homework | 1 | ||
| Light going through glass to make a rainbow | General Physics | 4 | ||
