How Can I Understand Logarithms and Their Graphs Better?
  • Thread starter Thread starter baltimores_finest
    Graphs Logarithms
The discussion revolves around understanding logarithms, particularly base 10 logarithms, and their graphical representation. The original poster expresses confusion about the concept and its applications, referencing specific questions from a textbook related to logarithmic functions.
  • Participants attempt to clarify the definition of logarithms and their relationship to exponents. Questions are raised about the behavior of logarithmic functions, including rates of change and specific values of logarithms for given inputs. Some participants suggest exploring the graph's characteristics and the implications of the logarithmic identity.
There is a mix of attempts to explain logarithmic concepts and the original poster's specific questions. Some participants provide insights into the fundamental properties of logarithms, while others express similar confusion, indicating a shared challenge in grasping the material. Guidance is offered in the form of explanations, but no consensus or complete solutions have emerged.
The original poster has provided a set of specific questions from their textbook, indicating a structured approach to their homework. There is an emphasis on understanding rather than simply obtaining answers, reflecting the forum's learning-first approach.
baltimores_finest
Logarithms...i need help.
A logarithm of a number is the exponent of the power to which a fixed number. called the base, must be raised to produce the given number.
I absolutely do not understand what these things mean. In my textbook it shows a graph of x=10y.
Then it follows with 6 questions which are as follows:
1. For what values of x do the corresponding logarithms change most rapidly?
2. How does the rate of change of y compare with that of x for values of x between 1 and 10?
3. For what values of x are the values of y negative?
4. What is the approximate value of y when x=8? 15? 28?
5. What is the number whose logarithm is .2? .4? 1.2? 1.4?
6. Show that in the graph log 10 is approximately equal to log 5+log 2; that log 5 is approximately equal to log 25-log 5. that log 27 is approximately equal to 3 log 3.
PLEASE ANSWER BUT EXPLAIN HOW THESE ARE DONE PLEASE...
Thanks.
:wink: Amber :wink:
I won't answer your questions for you, but I will try to explain logarithms so that you will understand them well enough to do them yourself.
If you take the equation
[tex]10^{2}=100[/tex]
Ten is the base, and 2 is the exponent.
A logarithm is basically solving for x in the following:
[tex]10^{x}=100[/tex]
here x = 2
for
[tex]10^{x}= 1000[/tex]
x=3
Another way of writing this would be
[tex]log_{10}1000 = 3[/tex]
Which would read "The log of 1000, base 10, is 3"
The general form of this equation is
[tex]log_{base}(number) = exponent[/tex]
The exponent (or log of the number) does not have to be a whole number.
Thus, the log of 5, base 10 would be 0.69897 or
[tex]log_{10}5 = 0.69897[/tex]
or of 15:
[tex]log_{10}15 = 1.1761[/tex]
Hope this helps
As your only worried about base 10 logarithms:
[tex]10^{log(x)} = x[/tex]
The above equation all you really need to know for now.
I assume that the graph in the book isn't x = 10y, but x = 10y, so just by looking at the above equation you should be able to see that y = log(x).
This phrase seems meaningless to me as well!.
I would have said:
A logarithm (with respect to a number B) of a number A is the power to which B must be raised in order to produce A.
The power to which we raise a number is often called the exponent;
the number to be raised is called the base.
If the base is B, the exponent that produces A is called the B-logarithm to A.
Read the other replies carefully; these detail the procedure needed to solve the problems.
