Finding the shortest possiblee travel time
  • Thread starter Thread starter dotfortun3
    Time Travel
The discussion revolves around optimizing travel time for a motorcycle and a car under specific acceleration and deceleration constraints. The motorcycle problem involves calculating the minimum time to stop after traveling 800 m, while the car problem focuses on finding the minimum time to travel 0.5 mi (804.672 m) starting and ending at rest.
  • Participants discuss the need to determine optimal speeds for acceleration and deceleration to minimize travel time. Some explore the implications of not reaching maximum speed before deceleration, while others question the assumptions made in their calculations.
Some participants have offered guidance on setting up equations for distance and speed, while others express uncertainty about their assumptions and calculations. There is an ongoing exploration of different approaches to the problems without a clear consensus on the best method.
Participants note the constraints of starting and ending at rest, as well as the specific acceleration and deceleration rates for both vehicles. There is a recognition of the complexity introduced when maximum speeds are not reached.
dotfortun3
A motorcycle can attain a maximum speed of 55 m/s, accelerate at 5 m/s^2 and decelerate at 7 m/s^2. If the motorcycle starts from a rest, find the minimum possible time it takes the motorcycle to stop exactly 800 m further down the road.
d=rt is the only one I could think of
Well, I know that I need to find the best speed to accelerate to, to be able to stop quicker and have the shortest time possible, but I really need help getting started with this
The minimum time for the trip is such that the mc accelerates to top speed as quickly as possible, and stays there until such time as the trip is completed by decelerating to 0 speed at the maximum possible deceleration rate. The time interval and the then the distances for the beginning and ending portions of the trip can then be calculated. With this information, the time interval for the middle constant speed portion can be found.
Thank you so much! I really was just over thinking the problem and thought that I was doing it wrong! I feel dumb now! :blushing: Thanks again!
I have a similar question to this problem. My car can accelerate uniformly (calculated to be 1.788 m/s^2) to 120 mi/h (53.6448 m/s) in 30 s, and its maximum deceleration is -6.86 m/s^2. I'm supposed to find the minimum time to travel 0.5 mi (804.672 m) with the car beginning and ending at rest.
My problem is that the car does not reach it's maximum speed before braking since the 30 s it takes to accelerate to maximum speed travels 0.5 mi to begin with, and the car must be at rest at the end. I'm having trouble trouble setting this problem up.
diablo, since your maximum speed will not be reached the problem becomes a little bit more complex. I would approach the problem by creating two distance equations for the car. One for the car speeding up and one for the car slowing down. You will have two unkowns in each equation which you will then solve for.
Thank you for the lead. I don't know if I got it right, but I started with two vf^2 = vi^2 + 2ax equations, one for speeding up and one for slowing down. Although I did not know vf for speeding up or vi for slowing down, I assumed the quickest would be if the car began to decelerate at a certain speed, hence my assumption is that vf and vi would be equal, a vmax if you will. Combining this with the knowledge that the distance of speeding up and the distance of slowing down ultimately added up to 0.5 mi, I set both equations to 0.5 mi and solved for a common max speed. Using this speed, I then plugged it into x = vi*t + 2at^2 to find the respective times for speeding up and slowing down from the presumed vmax.
I got an answer out of this method, but I'm not so sure that my assumptions give the minimum time it would take to drive 0.5 mi. See any flaws in my logic?
  • · Replies 26 ·
