Is My Calculation for Car Deceleration Speed Correct?
The discussion revolves around the calculation of car deceleration when braking from a speed of 100 km/h over a distance of 45.73 m. Participants explore the application of the kinematic equation v² = u² + 2as to determine the deceleration and discuss unit conversions.
  • One participant presents a calculation for deceleration using the formula a = (v² - u²)/2s, converting 100 km/h to m/s.
  • Another participant agrees with the approach but suggests that the conversion of 100 km/h to m/s may not have been accurate enough.
  • A later reply introduces the idea that in real-world scenarios, the deceleration rate is not constant and increases as speed decreases.
Participants generally agree on the method of calculation but express differing views on the accuracy of unit conversion and the nature of deceleration in real-world conditions.
There are unresolved aspects regarding the accuracy of the speed conversion and the assumption of constant deceleration in the calculation.
nic_nic344
Hey,
Just wanted to clarify that this was the right way to calculate the deceleration when braking from a speed of 100km/h when the braking distance of the car is 45.73m.
I am just using the formula v^2 = u^2 + 2as
Which i have rearranged to find a...
a = (v^2 - u^2)/2s ---------------- s = distance
And I converted the 100km/h to m/s
so...
a = (0 - 27^2) / 2 * 45.73
a = - 7.97ms/s
Is that right?
Or should I just leave the 100 in km...
and then by deceleration is like -100ms/s?
Thanks!
Welcome to PF!
nic_nic344 said:
Hey,
so...
a = - 7.97ms/s
Is that right?
Hi nic_nic344! Welcome to PF! :smile:
Yes that's right … you get everything into the same units … except that your 27 isn't accurate enough. :wink:
Hey,
Yeh I will change the units to something like .78
Thanks for your help!
real world the deceleration rate of a car is not steady state over the speed drop
it starts low and gets higher as speed drops
9K
  • · Replies 46 ·
13K
12K
