Forces exerted by two rods with uniform mass.
The discussion revolves around calculating the gravitational force between two uniform one-dimensional rods. The original poster attempts to derive the force by integrating over the mass elements of both rods, focusing on the x-direction due to symmetry. There is a hint to demonstrate the limiting behavior of the force as the separation between the rods becomes large compared to their lengths.
  • Participants discuss the integration process required to calculate the force, with the original poster providing a detailed attempt involving limits and substitutions. Some participants question the clarity of the original post and suggest using LaTeX for better readability. Others offer corrections and guidance on formatting equations in LaTeX.
The discussion is ongoing, with participants providing feedback on the clarity of the original poster's equations and offering assistance in converting text to LaTeX. There is no explicit consensus on the solution, but there is a collaborative effort to improve the presentation of the mathematical expressions.
Participants note the challenges of formatting equations properly in LaTeX, which may be affecting the clarity of the original poster's attempts. The original poster expresses frustration with the conversion process, indicating a learning curve in using LaTeX effectively.
Benzoate
Calculate the gravitational force betwee two uniform(1-D) rods as shown below.(hint you have to integrate the force over the mass elements of both rods . we did the first integral in class. As before you only have to worry about the componet in the x-direction by symmetry. Demonstrate that , in the limit that the separation of the rods becomes large compared to their lengths, the force the correct limiting form.
Here is a drawing of the two rods on my course webpage. You might have to click on the homework tab of the main page and then proceed to click on assignment three if link directly
fails to link you to the homework page containing the problem
http://courses.ncsu.edu/py411/lec/001/
principle of superposition for Forces
lambda=delta(m)/L=mass/length
General information about the forces between two or more rods
F=lim(as delta(x)==> 0) sigma(-G*m0*lambda*delta(xi) (x-hat)/(x0-xi)^2
F0=\lmoustache{-L/2 , L/2}(-G*m0*lambda(x)*dx/((x0-x)^2)*(x-hat)
since object is uniform, all lambdas are constant and therefore all lambda's equal lambda(0).
F0=integral(from -L/2 to L/2)(-G*lambda(0)*m(0)*(x-hat)/(b-x)^2=-G*m0*lambda(0)(x-hat) *integral(from -L/2 to L/2) dx/(b-x)^2. From u-substitution, I can say that :
u=b-x
du=-dx
F0=-G*m0*lambda(0)*(x-hat)*integral(from b-L/2 to b+L/2)(-du/u^2)=-G*m0*lambda(0)*x-hat[-1/(b-L/2)+1/(b+L/2)]
1/(b+L/2)-((1)/(b-L/2))= -L/(b^2-(L/2)^2)
F0=-G*m0*lambda*L*x-hat/(b^2-(L/2)^2)
in limiting case, as b>>L, then F0 = G*m0*M/b^2. My solution
let M/L=lambda
with cos(alpha)=b/r and r=sqrt(b^2+y^2)
by symmetry, the x component is the only left since force is only x direction.
F=integral(from -L/2 to L/2)dy(-G*m(particle)*lambda*dy/(r^2)*cos(alpha))x-hat=-G*m(particle)*lambda*integral(from -L/2 to L/2)b*dy/r^3=-G*m(particle)*lambda*b*integral( from -L/2 to L/2)
dy/(b^2+y^2)^(1.5)==>
==>G*m(particle)*lambda*b^-1*integral(from -L/2 to L/2)*(dy/b)/(1+(y/b)^2)^(1.5)
using u-substitution , I find that y=b*tan(theta)
dy=b*sec^2(theta)*dtheta
F=-G*m(particle)*lambda*b^-1*integral(from arctan(L/2b) to arctan(-L/2b)*(sec^2(theta)*dtheta/(1+tan^2(theta)= G*m(particle)*lambda*b^-1 integral(arctan(-L/b) to arctan(L/b)) dtheta/sec(theta)=-G*m(particle)*lambda*cos(theta)*dtheta=-G*m(particle)*lambda*b^-1*sin(theta)*integral(arctan)
F=-G*m(particle)*lambda*b^-1 * [(2L/b)/(sqrt(1+(L/b)^2)
F=-G*m(particle)*lambda*L*(1/(b*sqrt(b^2+L^2))
Force between two rods is r=sqrt(b^2+(y'-y)^2)
I'm not sure where to go from here :(
oh come on, Benzoate!
that's virtually unreadable … :frown:
either learn how to do LaTeX …
http://www.physics.udel.edu/~dubois/lshort2e/node61.html#SECTION008100000000000000000
http://www.physics.udel.edu/~dubois/lshort2e/node54.html#SECTION00830000000000000000
or use unicode characters and the X2 and X2 tags.
I am having difficulty using latex. I will paste one of the equations from my OP and you can show me how I can transformed text into latex: F0=integral(from -L/2 to L/2)(-G*lambda(0)*m(0)*(x-hat)/(b-x)^2=-G*m0*lambda(0)(x-hat) *integral(from -L/2 to L/2) dx/(b-x)^2
Sorry , I should have asked you. Can you show me how to transformed the above equation into latex?
LaTeX
I'll start you off … you get:
[tex]F_0 = \int_{-L/2}^{L/2}\frac{-G \lambda_0 m_0 \hat{x}}{(b - x)^2}[/tex]
if you type
[noparse][tex]F_0 = \int_{-L/2}^{L/2}\frac{-G \lambda_0 m_0 \hat{x}}{(b - x)^2}[/tex][/noparse]
Please look at those links I gave you!
I was unable to edit my OP , so I will have to repost my solutions.
[tex]F=\begin{displaymath}\lim_(n \rightarrow 0)\-int_{-L/2}^{L/2}\frac{-G \lambda_0 m_0 \hat{x}{( b-x)^2}[/tex]
u=b-x
du=-dx
[tex]F_0 =frac{-G \lambda_0 m_0 \hat{x}} \int_{b-L/2}^{b+L/2}\frac{{-du}{u}^2}[/tex]
just a test! still converting all my text into latex
still a test
I give up! I've worked on the same equation for latex for 30 min I've still failed to convert my equation into latex
LaTeX
Hi Benzoate! :smile:
Some corrections:
i] no need to type "begin displaymath" … tex will atuomatically assume it's maths, unless you type \text{}
ii] instructions like lim and ^ and _ must be followed by {}, not ()
iii] you typed \-int instead of \int, and left out some { and }s … ou must count thsoe brackets carefully :wink:
This, I think, is what you wanted …
[tex]F=\lim_{n \rightarrow 0}\int_{-L/2}^{L/2}\frac{-G \lambda_0 m_0 \hat{x}}{( b-x)^2}[/tex]
and you get it if you type:
[noparse][tex]F=\lim_{n \rightarrow 0}\int_{-L/2}^{L/2}\frac{-G \lambda_0 m_0 \hat{x}}{( b-x)^2}[/tex][/noparse]
Try again! :smile:
