Yet another static equilibrium problem.
The problem involves a wheel on a slope with a specific inclination angle and a mass distribution that affects its static equilibrium. Participants are tasked with finding an angle PHI that maintains this equilibrium, considering the forces and torques acting on the wheel.
  • Participants discuss the relationship between the forces acting on the wheel and the moments about potential pivot points. There is an exploration of how to set up the problem correctly to find the angle PHI.
Some participants have offered hints about taking moments and considering suitable pivot points. There is an ongoing dialogue about the appropriateness of different pivot choices, with no clear consensus on the best approach yet.
Participants express uncertainty regarding the placement of pivot points and the implications of those choices on the calculation of torques. The discussion reflects a need for clarification on these assumptions without resolving them.
akan
The figure shows a wheel on a slope with inclination angle 16 degrees, where the coefficient of friction is adequate to prevent the wheel from slipping; however, it might still roll. The wheel is a uniform disk of mass 1.35 kg, and it is weighted at one point on the rim with an additional 0.960 kg mass. Find the angle PHI shown in the figure such that the wheel will be in static equilibrium.
http://img181.imageshack.us/img181/9085/rw1261xj2.jpg
http://g.imageshack.us/img181/rw1261xj2.jpg/1/
I understand this:
m sin(phi) R = M sin(theta) R
However, this does not give me the right answer. So how do I solve this?
Hi akan! :smile:
Hint: you don't want the wheel to turn
so take moments about a suitable point (to find the torques of the forces), and put that equal to zero. :smile:
What would be a suitable pivot point here? Thanks.
moments of forces
oh come on! :rolleyes:
I can only see two possible pivot points …
choose one of them, and see if it works! :smile:
Sorry, I suck with pivot points. If I put it at the center, then gravity is acting parallel to the level arm, so that ain't going to work. If I put it at the circumference, then the whole thing is just going to be weird. So where do I place it?
Place it at the point of contact (between the wheel and the slope).
There, the torque of the reaction and friction forces will be zero (that's why you're choosing it :wink:), so you just have m and M to balance … like a see-saw! :smile:
  • · Replies 42 ·
