Force on Walls of Rectangular Potential Box by Particle Inside
The discussion revolves around understanding the force exerted on the walls of a rectangular potential box by a particle inside, specifically focusing on the proposition that this force can be expressed as the negative expectation of the derivative of the Hamiltonian with respect to the box's size. The scope includes theoretical considerations in quantum mechanics and the implications of quantization.
  • One participant proposes that the force on the wall is related to the work done when changing the size of the box, suggesting a connection to pressure and energy density.
  • Another participant expresses confusion about differentiating with respect to the size of the box rather than a coordinate, seeking a deeper understanding of this approach.
  • There is a suggestion to consider the box as a piston to clarify the relationship between the force and the box's dimensions.
  • One participant raises concerns about the complexities of quantum mechanics, mentioning concepts like adiabaticity and the elimination of center of mass motion, indicating that these may complicate the understanding of the problem.
  • Another participant emphasizes the importance of not overwhelming the original poster with advanced subtleties if they are struggling with the basic problem.
  • Several participants discuss the implications of quantizing the system and how it relates to the force exerted on the walls.
Participants express varying levels of understanding and agreement on the approach to the problem. Some agree on the analogy of the box as a piston, while others highlight the need for a more rigorous derivation and express confusion about the underlying principles. The discussion remains unresolved regarding the best way to derive the force expression.
Participants mention various assumptions and complexities, such as the relationship between potential energy and force in classical mechanics versus quantum mechanics, and the implications of adiabatic processes. These factors contribute to the uncertainty in deriving the proposed expression.
maverick280857
Hi everyone..
I'm trying to prove the following proposition:
The force exerted on the wall perpendicular to the x-axis by a particle of mass m contained in a rectangular box of dimensions a, b, c is given by the negative of the expectation of the derivative of the Hamiltonian wrt a:
[tex]F = -\left\langle \frac{\partial \hat{H}}{\partial a}\right\rangle[/tex]
But I can't see why I should differentiate with respect to the size of the box. Any ideas? This proposition is given in Landau/Lifgarbagez.
Thanks in advance.
I love this problem.
Think about this like a Halliday and Resnick problem. I have a pressure on the walls, so when i push them in, I need to apply a force. If I apply the force F through an infinitesimal distance dx, I do work dE. So F = dE/dx. Now it's simply a matter of recognizing that I can't change x without changing a, and then quantizing the system.
Thanks for your reply Vanadium.
Thats what I am trying to understand more deeply. x is just a coordinate here and classically I would have to differentiate potential energy with respect to the coordinate to get the force. Here however, I am differentiating wrt to the size of the box. What do you mean by changing x and then quantizing the system? Could you please elaborate.
If I squeeze in on the box, I make it smaller, no?
"Then quantizing the system" means "solve using QM".
Now that I think about it more, maybe this will help.
Suppose someone gave you a box, and asked you what the pressure was. You don't (yet) know the contents of the box, but suspect it's some number of particles bouncing around inside (like a gas). You'd measure the force on the walls, probably by squeezing it and measuring the resistance - or, equivalently, by seeing how much work you had to do on it.
So measuring the pressure is equivalent to measuring dE/dx. (In fact, pressure has dimensions of energy density)
Now, I tell you what's in the box - a single particle. Given your knowledge of QM, you can calculate dE/dx from that. Now you have all the pieces.
I'm a dunce, I still don't get the idea behind differentiating it wrt to the size of the box. Is a more rigorous 'derivation' of this equation possible?
Does it help to replace the "box" with a piston?
The problem is not so simple. Landau never liked to think about fundamentals of QM.
1. You should think about adiabaticity. Is it possible to have 900 shift of phase between F and C (length of box) for sinusoidal C change in time?
2. Has the box exact 0 position? Is then the momentum of the box equal to infinity? What is then?
3. Elimination of center of mass motion is the most unsolved (it is more unsolved than solved, remember Messbauer effect and Nobel prize, Landau criterium for superfluidity) problem in QM.
If the OP is having trouble with the problem as is, it's probably not going to help him to immediately launch into subtleties.
See, I understand that in CM, the force is equal to minus one times the partial derivative of potential energy with respect to position x. Can you tell me how it generalizes to this form in Quantum Mechanics and why am I differentiating with respect to the size of the box?
Vanadium, I get your point about having to change a before I can quantize the system. I think I have an intuitive feel for the expression, but I don't see how I can derive it...any ideas in this direction are particularly welcome.
It's a piston. Push on it, and it gets smaller. That's why you are differentiating it with respect to the size of the box.
Hmm okay, thanks Vanadium.
  • · Replies 41 ·
11K
  • · Replies 19 ·
