Register to reply
Calculating Final Temperature
by grapejellypie
Tags: calorimetry, heat capacity, thermochemistry
Share this thread:
grapejellypie
#1
Oct5-08, 07:10 PM
P: 14
A 505g piece of copper tubing is heated to 99.9 degrees C and placed in an insulated vessel containing 59.8g of water at 24.8 degrees C. Assuming no loss of water and a heat capacity for the vessel of 10.0 J/K, what is the final temperature of the system? (c of coppuer is 0.387 J/(gk))
2. Relevant equations
q = c x mass x change in temperature
change in termperature = T[final] - T[initial]
3. The attempt at a solution
I have no idea how to go about solving this problem
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Borek
#2
Oct6-08, 02:16 AM
Admin
Borek's Avatar
P: 23,600
Heat lost = heat gained.
grapejellypie
#3
Oct6-08, 02:43 AM
P: 14
how do you account for the two separate systems combining into one?
(i.e. how would you deal with the two different masses?)
Borek
#4
Oct6-08, 02:58 AM
Admin
Borek's Avatar
P: 23,600
Treat heat gained/lost separately. Use equation you have already posted for each mass separately. The only commong thing in both equations will be the final temperature, and that's what you will solve for.
grapejellypie
#5
Oct6-08, 03:00 AM
P: 14
how do you incorporate the heat capacity of the vessel?
Borek
#6
Oct6-08, 03:38 AM
Admin
Borek's Avatar
P: 23,600
Combine it with water (simply add them, nothing more fancy). It coul be given as vessel mass and specific heat, but the heat capacity is the same, just details are hidden - which completely doesn't matter.
Register to reply
Related Discussions
Calorimetry- how do I know the final temperature? Biology, Chemistry & Other Homework 2
Final temperature of system Introductory Physics Homework 2
Calculating final Velocity Introductory Physics Homework 3
Finding final temperature Introductory Physics Homework 1
Final temperature Introductory Physics Homework 0
