How Does Magnification Affect Object Distance in Lens Optics?
  • Thread starter Thread starter Dx
    Light Optics
The discussion revolves around lens optics, specifically focusing on how magnification affects object distance in relation to a lens with a 50mm focal length and a biconvex lens with a given refractive index. Participants are exploring the relationships between object distance, image distance, and magnification.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of the lens equation and magnification formulas to determine object distance and focal length. There are attempts to clarify the correct application of these equations and the implications of the given parameters, such as focal length and refractive index.
There are multiple interpretations of the problems being discussed, with some participants questioning the assumptions made about the lens types and the values used in calculations. Guidance has been offered regarding the correct formulas to use, but no consensus has been reached on the specific answers to the problems.
Participants note potential confusion regarding the values for the refractive index and the appropriateness of the equations being applied. There is also mention of the need for clarity on whether the lens is convex or concave, as this affects the nature of the image formed.
Dx
Hi!
I have 2 problems that I need some help with, please.
1) How far from a 50mm focal length lens, such as used in many 35mm cameras, must an object be positioned if it is so to form a real image magnified by a factor of 3?
how do i solve for this? I have tried to solve using lens equation but not the answer I would expect, my answer is 52mm. Is this correct if not how did you go about solving for this?
2) A biconvex lens is formed by using a piece of plastic(n=170). the radius of the front surface is 20cm and the radius of the back surface is 30cm. what is the focal length of the lens?
I know that r/2 = f but should i add both radius's and use that /2? I need some help?
Thanks!
Dx
:wink:
Hi Dx,
1) Sorry I can't reproduce your answer. What equation did you use, and what values did you plug in?
Anyway I think it's a strange question since in most cases a camera image will be much smaller than the object.
2) I think r/2=f can't be the correct equation since the refractive index n doesn't appear in it. Plus I doubt that the value n = 170 is correct. You would rather expect n to be in the range between n=1 and n=2. As for a biconvex lens, you should add the inverses of both focal lengths to get the inverse focal length, i.e. 1/f = 1/f1 + 1/f2.
My equation used was 1/do + 1/di = 1/f, since my f lenth is 1/50mm i tried to solve for do. Unless i am incorrect i believe that do and f are the same distance, right? that's how i solved for it using substitution. But the factor of 3 forlateral magnification, right?
m=+3, so di=m*do = 20cm. Sorry I don't have all my notes but i am trying to remember all my steps, i substituted the do answer to get 1/do - 1/f to get my answer. I am starting to think I am really confused here. Yes! Its a very strange question i think not enough info i though at first but my teacher sasy there's enough to solve. I am going to keep trying anyways...thanks!
I think for the particular problem its refractive index n = 1.7 but your correct its normally not. i remeber reading that to get the f = r/2 but i need the inverses of the f to solve for this your saying, sir? I think the formula i found is it!
1/f = (1.7-=1)(1/20+1/30) = 17cm
is 17cm correct?
I would appreciate anymore of your help, I am still lost?
Thanks!
Dx :wink:
That is IMO correct.
I think this is wrong. Because if you place the object in the focus, there will be no image. I think you should rather use di = 3*do, since you want a magnification of 3.
Yes you need a proper formula for calculating f1 and f2. The value of n must appear in this formula. Then you use the formula I gave above. Remember this is only correct, if lenses are thin.
I am guessing that it is convex since a there is no way to get a magnified image with a concave.
m=-di/do
di=-3do
1/f=1/do - 1/3do
1/f=3/3do - 1/3do
1/f=2/3do
2f/3=do
2(50mm)/3=do
33.33mm=do, here is your answer
