Collisions and conservation of momentum
The discussion revolves around a problem involving collisions and the conservation of momentum, specifically focusing on an inelastic collision between railroad cars. The original poster attempts to calculate the final velocity of the coupled cars after the collision and subsequently explores the change in kinetic energy (KE) during the event.
  • Mixed
  • Participants discuss the application of the conservation of momentum formula to find the final velocity after the collision. There are attempts to calculate initial and final kinetic energy, with some participants questioning the accuracy of their calculations and the interpretation of kinetic energy loss.
Some participants have provided guidance on recalculating values and checking for errors in the calculations. There is acknowledgment of confusion regarding the definitions of change in kinetic energy versus kinetic energy lost, indicating a productive exploration of the topic.
Participants are working under the constraints of a homework assignment, which may impose specific requirements for calculations and interpretations of physical concepts.
rinarez7
1. A railroad car of mass 28400kg moving at 2.33 m/s collides and couples with two coupled railroad cars, each of the same mass as the single car and moving in the same direction at 1.06 m/s. What is the speed of the three coupled cars after the collision? Answer in units of m/s
2. m1v1i +m2v2i = (m1 +m2) Vf
3. I thought that since this is an inelastic collision, once the three rail road cars stuck together, their final velocity would be the same. So using the equation above, and solving for Vf :
28400 kg (2.33 m/s) + 2x 28400 kg (1.06 m/s) = ( 85200 kg) Vf
66172 + 60208 = 85200 Vf
Vf= 0.7767 m/s
But this isn't correct = ( Any help please?
Looks good.
Vf= 0.7767 m/s
Redo that last calculation.
Okay! now I got 1.483 m/s, which is correct! Thank you!
There is a second part though which has also stumped me.
It asks, how much KE is lost in the collision, answer in units of J?
KEf-KEi = change in KE
KEi = (.5) m1v1^2 + (.5)m2v2^2
KEi = (.5) 28400kg (2.33m/s ^2) + (.5) 2x 28400kg (1.06 m/s^2)
KEi = 77090.38 + 31910.24 = 10900.62 J
KEf = (.5) (m1 +m2)Vf
KEf = (.5) (85200kg) 1.483 m/s = 63190 J
Therefore chanGE IN KE = 63190 J - 10900.62 J
But I seem to be missing something...
Check that last step. (Decimal point!)
Don't forget to square the speed.
Also, how much is "lost" will be KEi - KEf.
Thanks! I was confusing "change in KE" with how much is "lost" I squared the speed and subtracted KEf from KEi and got 15310.92 J!
