Thread Closed
impact velosity
Share Thread Thread Tools
Oct22-08, 07:06 PM   #1
impact velosity
I am developing a new product. I am currently constructing various prototypes of the product changing only one component using a different material with each model.
I want to test the impact results of each different model dropping a consistent weight (i.e. 20lbs) from a consistent height (i.e. 10’) for each test so video these results to determine which model will best suit my needs.
So, this sounds like a simple question, dropping 20lbs from 20’, what will be the velocity at impact? And is there a simple formula I can use if I change the variables?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Soft matter offers new ways to study how ordered materials arrange themselves
>> Making quantum encryption practical
Oct22-08, 09:18 PM   #2
Quote by bp1945 View Post
If the products that you are dropping are relatively aerodynamic you can use a very simple formula:
[tex]v=\sqrt{2ad}[/tex],
where
v is the velocity when the object hits the ground (ft/s)
a is the acceleration due to gravity (32.17 ft/s2)
d is the height you dropped it from (ft).
Oct23-08, 12:31 PM   #3
Hey gamesguru, thanks for your response. After reading your response and re-reading my question I realise I didn't make it quit clear.
I'm not dropping the product, the product will be stationary and paralell to the ground and I will be dropping the weight from a certain height straight down on the product to determine velocity and record (video) impact damage.
And gamesguru, I am worse than terrible at math so that formula scared the hell out of me. Can you do an example using 20lbs as the weight and 10ft. as the distance dropped. What I need to know is the velosity at impact using those two variables. And I may change variables to get different results.
Can you explain this to me in idiot terms?
Oct26-08, 09:53 AM   #4
impact velosity
As long as you work with fairly heavy weights, the role of air resistance will be negligible and so the weight will not matter, only the height will determine the impact velocity.
If you use my above formula, you will find (in feet):
[tex]velocity=\sqrt{64.34*height}[/tex].
You can use google now. To find the impact velocity at 10 feet just type "sqrt(64.34*10)" (without quotes) into google, hit enter. You will get 25.36. This means your weight will hit the product at a speed of 25.36 feet per second.
Hope that helps.
Oct28-08, 10:56 AM   #5
Thanks gamesguru, this helps greatly.
Thread Closed
Tags
height, impact, velosity, weight
Thread Tools
Similar Threads for: impact velosity
Thread Forum Replies
Impact Introductory Physics Homework 2
Average Velosity!! Introductory Physics Homework 0
impact General Physics 1
'Deep Impact' Impact... General Astronomy 1
