Help with srain on steels please
  • Thread starter Thread starter bullvine
The discussion focuses on calculating strain in a steel rod subjected to a tensile load. A 14mm diameter rod experiences a load of 3.08 kN, resulting in a stress of 20 MPa. Given the Young's Modulus (E) of 200 GPa, participants confirm that strain can be calculated using the formula E = stress / strain. Additionally, the extension of the rod can be determined using the strain formula: Strain = (New Length - Original Length) / Original Length.
  • Understanding of stress and strain concepts in materials science
  • Familiarity with Young's Modulus and its application
  • Basic knowledge of tensile load calculations
  • Ability to manipulate algebraic equations for engineering problems
  • Study the relationship between stress, strain, and Young's Modulus in detail
  • Learn how to calculate the extension of materials under various loads
  • Explore different types of materials and their respective elastic properties
  • Investigate practical applications of strain gauges in measuring deformation
Mechanical engineers, materials scientists, and students studying structural engineering or mechanics of materials will benefit from this discussion.
bullvine
Hi to all.
I am new on here and require some help on how to find out strain on a steel rod when all is known.
A 14mm rod carries a load of 3.08kn in tension.
i need to calculate the stress( this I know how to do) the answer is 20mpa.
The length is 2.5m,whats the strain? and find out the change in length. the E or elasticity is 200gpa.
I would appreciate your help
Cheers
Well the formula for elasticity (a.k.a Young's Modulus) is E = stress / strain.
You already know E and you've calculated stress, so plug the numbers into the equation and find your strain.
If you want to go further, you can calculate the extension of the steel rod by using the formula for strain: Strain = (New Length - Original Length) / Original Length
Good luck with your studies.
  • · Replies 53 ·
11K
