Find work on a straight line path
The problem involves calculating the work done by a variable force on a proton as it moves along a straight-line path between two specified points. The force is defined as F=<-ax², 0> with a given value for 'a'. The context is rooted in classical mechanics, specifically in the area of work and energy.
  • Participants discuss the appropriate equations for calculating work, questioning whether to use W=F*change in x or W=F*change in r due to the nature of the force being non-constant. There is a focus on understanding the path of the proton and the need to parameterize it for integration.
Some participants have recognized the necessity of using the integral form of work due to the non-constant force. Guidance has been offered on how to parameterize the straight-line path, with an example provided for expressing the coordinates in terms of a parameter. However, there remains uncertainty among participants regarding the concept of parameterization and its application.
Participants express confusion over the terminology and the mathematical steps involved in parameterizing the path, indicating a need for further clarification on these concepts.
steph3824
In an experiment, one of the forces exerted on a proton is F=<-ax2,0> where a =12N/m2. Calculate the work done by this force as the proton moves along a straight-line path from the point ri=<0.10m,0> to the point rf=<0.30m, 0.40 m>
I'm not sure if I would use W=F*change in x (don't know how to type in the delta symbol) since it says it's a straight line path, or if I would use W=F*change in r since the problem contains r's in it
I'm not too sure what to do here. I see that I'm given a Fx and Fybut I don't know exactly what to do with the multiple r's. Thanks for any help!
Where the force is not constant as is the case here, you must use the general definition of the work done be a force. That is
[tex]W = \int_\gamma \bold{F}\left(\bold{r}\right)\bold{\cdot}d\bold{\gamma}[/tex]
Where [itex]\bold{\gamma}[/itex] is the path.
Oh ok I didn't realize that the force wasn't constant so I understand why that equation would be used. I still need help though..I'm not sure where to go with that equation
Okay. Generally with these types of questions, it is best to determine the path first. You have already figure out that the path is a straight line, so the next thing to do is to parametrise it. Can you do that?
No, I'm not sure what parametrise means.
Okay, it simply means write the equation of the straight line in terms of a parameter. You know that the general form of a straight line is y=mx+c, but writing the path in this form doesn't really make it easy to evaluate the path integral. Instead we want to write the x and y coordinates separately in terms of a parameter, say t.
In this case we know that the path is a straight line and can be written in the form
[tex]y=mx+c = \frac{0.4}{0.2}x - 0.2 = 2x - \frac{1}{5}[/tex]
Now, we need to parametrise this line. Let's start by letting
[tex]x = t \hspace{1cm}\text{where }\frac{1}{10}\leq t \leq \frac{3}{10}[/tex]
This will give us the change in x as we follow the path. Now we need to obtain an equation for y. All we need to do now is substitute x=t into the equation for our straight line to obtain
[tex]y = 2t - \frac{1}{5}[/tex]
Hence we have parameterise our path
[tex]\gamma = \left\{\begin{array}{l} x = t \\ y = 2t - \frac{1}{5}\end{array}\right.\hspace{1cm}\frac{1}{10}\leq t \leq \frac{3}{10}[/tex]
Do you follow?
  • · Replies 19 ·
13K
