| Thread Closed |
Trouble with Cross Product |
Share Thread | Thread Tools |
| Oct30-08, 07:18 PM | #1 |
Vector A = 3.5i + 1.8j and vector B = 1.7i + 4.8j . Find the components of A x B: 2. Relevant equations AxB = AB sin(theta) 3. The attempt at a solution Since vector A=3.5i+1.8j and B=1.7i+4.8j, I translated that into vectors. So, A is 3.94 @ 27.77*, and B is 5.09 @ 70.56*. This means that the angle between A and B is 42.79*. Using the AxB formula, I have 13.62. However, the problem (it's on WebAssign) wants the i, j, and k components. I tried the AxB formula with the individual i and j components, and I got 4.04 for the i direction, and 5.87 for the j direction. However, they're both wrong, and I have no idea how to find out the k direction... Help! Thanks in advance, -Angel. |
| Oct30-08, 09:05 PM | #2 |
k is the third dimesion (or 3rd component in this case). A and B are 2 dimensions.
| Oct30-08, 09:13 PM | #3 |
I understand that the i, j, and k components are the x, y, and z directions, respectively. My frustration is that I believe I'm following the correct formula, but I still get the wrong answer. Where is my reasoning flawed?
I have tried the following: AxB = (3.94)(5.09)sin(42.79) = 13.62, however, WebAssign wants the answer in components. So, I tried this: AxB = (3.5i)(1.7i)sin(42.79) = 4.04i and then AxB = (1.8)(4.8)sin(42.79) = 5.87j When I entered these two (out of three) answers, they were both marked wrong. |
| Oct30-08, 09:17 PM | #4 |
The formula you try to use is for the magnitude of the vector axb, but the question asks for the vector itself.
Do you know the way to calculate a cross product as if it were a determinant? axb=|i j k; a_i a_j a_k; b_i b_j b_k| |
| Oct30-08, 09:19 PM | #5 |
When you cross two vectors the resultant vector will be orthogonal to both original vectors. Keep that in mind.
| Oct30-08, 10:47 PM | #6 |
You can multiply by components, but:
i x i=0 (same for j x j) i x j =k j x i = -k Try this. Newer mind the sin. Multiply the two vectors as you'll do for two binomials. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Trouble with Cross Product
| Cross product vs dot product headache | Advanced Physics Homework | 9 | ||
| Can anyone describe to me the difference between dot product and cross product? | Calculus & Beyond Homework | 3 | ||
| Having trouble grasping the Cross Product | Classical Physics | 28 | ||
| Wedge Product/Cross Product? | General Math | 2 | ||
