Velocity of a particle in a parallel plate, electric field problem
The discussion focuses on the motion of a charged particle in a uniform electric field, specifically a particle with a mass of 2.0 x 10^-5 kg and a charge of +2.0 microCoulombs in a 12 N/C electric field. The horizontal distance traveled by the particle in 5.0 seconds is calculated to be 0.3 meters, with a horizontal component of velocity at that point of approximately 0.8485 m/s. Additionally, the charge on each plate of the parallel plates is determined to be 2.6556 x 10^-13 Coulombs using the formula Q = EA / (4πk).
  • Understanding of Newton's second law of motion
  • Familiarity with kinematic equations
  • Knowledge of electric fields and forces
  • Basic principles of electrostatics, including charge and capacitance
  • Study the derivation and application of kinematic equations in electric fields
  • Learn about the relationship between electric field strength and force on charged particles
  • Explore the concept of projectile motion in the context of electric forces
  • Investigate the calculation of charge distribution on parallel plates in electrostatics
Students in physics, particularly those studying electromagnetism and kinematics, as well as educators looking for examples of particle motion in electric fields.
chem1
A particle with a mass of 2.0 x10^-5 kg and a charge of +2.0 microColoumbs is released in a (parallel plate) uniform horizontal electric field of 12 N/C
a) HOw far horizontally does the particle travel in 5.0 s?
b) What is the horizontal component of its velocity at that point?
c) If the plates are 5.0 cm on each side, how much charge is on each?
I think I can use
a) F= qE = q(-Ey)
F= -qE= may
-qEy/m= ay but for x
b) x= xo + V0t + 1/2 at
V^2 = Vo^2 + 2a (x-xo)
c) E= 4(pi)kQ/ A => Q= EA/ 4(pi)k
a) I assumed the above equation would be the same if applicable to x-axis, assuming the direction of the velocity is positive on the horizontal, I got
ax= qE/ m => a= (2.0 x10^-6) (12 ) / (2.0X10^-5) = 1.2 m/s^2
from that acceleration, I assumed, since the behaviour of the particle would be like a projectile motion since the electronegative field would attract the particle downward, the x-component of the velocity does not change, so v = vo then, I used the regular equation of kinematics to find x
x= xo + volt + 1/2 at, since Vo and xo are assumed to be 0, I got
x= 0 + 0 + 1/2 (1.2 m/s^2) (0.5s)= 0.3 m
Am I doing and assuming the right thing??
b) Then I can get from the velocity equation Vx
V^2= Vo^2 + 2a (x-xo)
sqrt ((2 (1.2 m/s^2) (0.3 m)
=0.8485 m/s
c) According to the general formula, to get the charge on each plate would be
Q= EA/ 4(pi) k
Q= (12 N/C) ( 0.5 m)^2 / (4(pi) (8.99 x10^9)
= 2.6556x 10^ -13
Note that the question states that the electric field is horizontal. Therefore, the electric force will be acting horizontally and the weight of the charge will be acting vertically. Since the charge experiences a non-zero force in both the x and y directions, neither the x nor y component of the velocity will be constant.
Does that make sense?
  • · Replies 58 ·
