Mass with a Charge in side an electric field
The discussion focuses on a physics problem involving a block with mass m and charge +Q connected to an insulating spring with force constant k, placed in a uniform electric field of magnitude E. Key questions include determining the maximum expansion of the spring, the equilibrium position of the block, and proving that the block's motion is simple harmonic while calculating its period. Additionally, the scenario is modified to include friction, requiring the coefficient of kinetic friction, μk, to be considered in the analysis.
  • Understanding of simple harmonic motion (SHM)
  • Knowledge of electric forces in uniform electric fields
  • Familiarity with spring mechanics and Hooke's Law
  • Concept of friction and its coefficients, specifically kinetic friction
  • Study the principles of simple harmonic motion and its mathematical representation
  • Learn about electric force calculations in uniform electric fields
  • Explore the effects of friction on motion and how to calculate the coefficient of kinetic friction
  • Investigate the dynamics of systems involving springs and external forces
Students and educators in physics, particularly those focusing on mechanics and electromagnetism, as well as anyone preparing for exams involving these concepts.
shinobi12
A block having mass m and charge +Q is connected to an insulating
spring having force constant k. The block lies on a frictionless, insulating horizontal track, and the system is immersed in a uniform electric field of magnitude E
The block is released from rest at a moment when the spring is unstretched (that is, when x = 0).
(a) By what maximum amount does the spring expand?
(b) What is the equilibrium position of the block?
(c) Show that the block’s motion is simple harmonic and determine its period.
(d) What if? Repeat part a, assuming now that there is friction between the block and track. Take mew sub k as the relevant coe¢ cient of kinetic friction.
Not sure how to tackle this problem.
Since your not told anything about whether the block is an insulator or conductor or the dimensions of the block or how the charge distributes itself through the block; the best you are going to be able to do is to assume it can be effectively treated as a point charge with mass [itex]m[/itex] and charge [itex]Q[/itex]...What is the electric force on such a charge when it is put in an electric field [itex]\vec{E}\hat{x}[/itex]? (I assume that the field is in the x-direction here?)...What other forces are being exerted on the charge?
  • · Replies 31 ·
  • · Replies 32 ·
  • · Replies 18 ·
