What is the best method for finding the argument of a complex number?
The discussion revolves around finding the argument of a complex number, specifically using the relationship tan(θ) = y/x, where z = x + iy. Participants explore the implications of using tangent, sine, and cosine in determining the argument and the potential confusion arising from the periodic nature of the tangent function.
  • Participants discuss the reliability of using tangent versus sine and cosine for finding the argument of a complex number. There are questions about the conditions under which each method yields correct results, particularly regarding the signs of x and y.
Some participants suggest that using arctangent can lead to ambiguity without considering the signs of x and y. Others propose that using sine and cosine might simplify the process, though there is no clear consensus on the best method. The conversation indicates a productive exploration of the topic, with various interpretations being examined.
Participants note the importance of understanding the signs of x and y when using trigonometric functions to find the argument, as well as the limitations of each function in providing a unique solution.
Niles
Hi all.
When finding the argument of a complex number using tan(\theta) = y/x (where z = x + iy), sometimes I do not get the correct answer. I assume this is because tangent is only defined for -pi/2 to pi/2 (and from this it is periodic).
So is it a good idea always to find the argument of a complex number using cosine and sine? Or am I missing something here?
Thanks in advance.
Regards,
Niles.
if you use cos and sine, you should still get the same theta if you use tan. Think of it as a triangle, where z is the hypotenuse, x is the base, and y is the height.
As in the figure at the top of this page:
http://en.wikipedia.org/wiki/Complex_plane
Niles said:
Hi all.
Thanks in advance.
Regards,
Niles.
There is nothing wrong with using tangent (more correctly arctangent) as long as you keep track of the signs of x and y. For example if you find that y/x= 1, then arctan(1) could be [itex]\pi/4[/itex] or [itex]5\pi/4[/itex]. If you know that x and y are positive then you know the argument is [itex]\pi/4[/itex], if negative, [itex]5\pi/4[/itex].
First, thanks to all for replying.
But I can avoid all of this "confusion" by using sine or cosine? I mean, what if only x is negative and y is positive. Then using arctangent I have to add pi/2 to get the correct result.
What do you mean by "using" sine and cosine? Yes, [itex]tan(\theta)= y/x[/itex] can be interpreted as [itex]sin(\theta)= y/r[/itex] and [itex]cos(\theta)= x/r[/itex]. If you only find [itex]arcsin(y/r)[/itex] where y is positive, you still have two possible answers [itex]\theta[/itex] between 0 and [itex]\pi/2[/itex] and [itex]\pi/2- \theta[/itex]. You can, of course, decide which you want by looking at [itex]arccos(x/r)[/itex] but it seems to me simpler to just find [itex]\arctan(y/x)[/itex] and look at the signs of x and y. That way you don't have to calculate [itex]r= \sqrt{x^2+ y^2}[/itex].
Perhaps getting to know the handy-dandy http://en.wikipedia.org/wiki/Unit_circle" will help you avoid this confusion? That way you'll get a sense on what happens when either X or Y is positive or negative.
So what I can conclude from your answers is that there is no way using arctan, arccos or arcsin to find the "correct" angle all the time, but it depends on the values of x and y?
no, you can find the angle using arctan, arccos, arcsin if you know x,y, and z.
are you familiar with the term: SOHCAHTOA?
just remember that the answer can range from 0 to 2pi, because that depends on the signs of x and y.
You cannot determine it by using any ONE of those without taking the signs of x and y separately into account.
I think you have misunderstood the question.
  • · Replies 18 ·
