| Thread Closed |
Optics--Diffraction of Thin Hair |
Share Thread | Thread Tools |
| Nov11-08, 09:10 PM | #1 |
A human hair is illuminated with a laser and it produces a diffraction pattern on a screen 1.09 m away. If the distance from the center to the first minimum is 4.8 mm and the wavelength of the laser is 748 nm, what is the thickness of the hair? Express your answer in mm. 2. Relevant equations wavelength = (x/m)*(w/l) x= distance from central maximum to position of the minimum m l= distance w= width m = minimum 3. The attempt at a solution I converted 748nm to mm and 1.9m to mm and plugged in the values into the above equation and got .296 mm approximately. I set m = 1, because I thought it was asking for the 1st minimum. And x = 4.8...but the answer I got is wrong. Any help? |
| Nov11-08, 10:53 PM | #2 |
I didn't go through your question, but I would have used the diffraction equation:
[tex]d\sin\theta=m\lambda[/tex] You can treat an opaque body as a "slit". See Babinet's Principle |
| Nov11-08, 11:30 PM | #3 |
In the problem you say 1.09 m and then you use 1.9 m.
With 1.09 m you get around 170 microns (or 0.17 mm) which is OK for the thickness of hair. |
| Nov12-08, 08:44 AM | #4 |
Thank you very much!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Optics--Diffraction of Thin Hair
| optics / interference in thin films | Introductory Physics Homework | 1 | ||
| Optics Thin Lens Equation | Introductory Physics Homework | 1 | ||
| Optics - Thin Lens Formula | Introductory Physics Homework | 2 | ||
| Can you reverse transform a thin film diffraction pattern? | General Physics | 6 | ||
| Optics, concerning a thin film | General Physics | 4 | ||
