Is T: M22 --> R a Linear Transformation?
  • Thread starter Thread starter FourierX
    Linear
The discussion revolves around determining whether the function T, defined from the space of 2x2 matrices (M22) to the real numbers (R), qualifies as a linear transformation. The function is expressed as T [a b; c d] = a + b + c + d.
  • Exploratory, Assumption checking
  • Participants explore the properties of linear transformations, specifically checking the conditions T(u + v) = T(u) + T(v) and T(ru) = rT(u). They discuss the implications of these properties using specific matrices and arbitrary scalars.
Some participants have confirmed that the first condition appears to be satisfied, while others are verifying the second condition. There is an ongoing exploration of whether both conditions hold true for the function T.
Participants are working under the assumption that the definitions of linear transformations are correctly applied, and they are using specific matrices to test these properties. The discussion reflects a collaborative effort to clarify the requirements for T to be a linear transformation.
FourierX
Linear Transormation?
Is function T a linear transformation for T: M22 --> R by
T [a b]
[c d] ( i.e. T [a b ; c d] )= a + b + c + d
T ( u + v) = T(u) + T(v)
T(ru) = rT(u)
The matrix form is confusing me
Let U be the matrix you defined and let r be an arbitrary scalar. You know how to calculate rU and you have the formula for calculating T(U), so does T(rU) = rT(U)?
For the next part, define another matrix similarily as you did except with different letters. Call it V. Does T(U + V) = T(U) + T(V)?
the first part T(rU) = rT(U) satisfies
and i so does the second part! Am I right?
If you can show it then you are done.
  • · Replies 24 ·
  • · Replies 18 ·
