Incident Intensity of light transmitted
  • Thread starter Thread starter Kathi201
    Intensity Light
An unpolarized beam of light passes through three polarizing sheets, each rotated 45 degrees from the previous one. The intensity transmitted through each polarizer is halved, resulting in a calculation of Io/2 for the first sheet. Continuing this process through all three sheets leads to a final intensity of Io/8. The consensus is that the fraction of the incident intensity transmitted is Io/8. This conclusion is reached by applying the intensity reduction factor through multiple polarizers.
Kathi201
An unpolarized beam of light is incident on a group of three polarizing sheets that are lined up so that the characteristic direction of each is rotated by 45 degrees clockwise with respect to the preceding sheet. What is the fraction of the incident intensity Io that is transmitted?
a. zero
b. Io/2
c. Io/4
d. Io/6
E. Io/8
My thoughts were that if you take the cosine of the angle 45 and square it as shown in the intensity equation you get .5, so therefore the answer would be Io/2, but I am not quite sure if this theory is right.
You need to consider what happens as the light passes through each polarizer.
as it passes through each sheet .5 is passed through each polarizer and there is three of them so would you take .5 x .5 x .5 = .125 which would be E. Io/8 ?
You got it.
Thanks for your help!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
