Number of quarks inside a nucleon
  • Context: Graduate
  • Thread starter Thread starter TheMan112
    Nucleon Quarks
The discussion revolves around determining the number of quarks inside a nucleon, particularly through the Gross-Llewellyn-Smith (G&L-S) sum rule and its implications based on neutrino-nucleon scattering data. Participants explore the mathematical relationships and equations involved in this determination, including the roles of valence and sea quark distributions.
  • One participant expresses confusion about deriving the number of quarks from the G&L-S sum rule, noting that it equals three based on specific equations related to neutrino scattering.
  • Another participant suggests treating the problem as a system of equations involving valence and sea quark distributions, indicating that integrating these could yield the required results.
  • A participant presents a complex expression for the quark distribution, questioning how to extract the necessary quantities for integration.
  • Some participants highlight that the G&L-S sum rule involves oversimplifications, with experimental results suggesting a value closer to two-and-a-half rather than three, raising questions about the accuracy of the theoretical model.
  • There is a discussion about the systematic errors in experimental measurements, with one participant seeking clarification on how these errors are estimated.
  • Another participant derives an expression for antiquarks and discusses how to calculate valence quarks by subtracting the antiquark distribution from the total quark distribution.
  • Uncertainty is expressed regarding how to achieve an integer result when integrating the derived expressions using the G&L-S framework.
Participants do not reach a consensus on the derivation methods or the implications of the G&L-S sum rule, with multiple competing views and uncertainties remaining in the discussion.
Participants note that the G&L-S sum rule is based on certain assumptions and simplifications, and the experimental results introduce additional complexities that are not fully resolved in the discussion.
TheMan112
I've been banging my head against the wall for days now trying to figure out how one determines the number of quarks inside the nucleon.
I understand it comes from the fact that the Gross-Llewellyn-Smith sum rule is equal to three:
[tex]\int ^1 _0 F_3 ^N (x) = \int ^1 _0 (u_V (x) + d_V (x)) = 3[/tex]
This is based on neutrino-nucleon scattering data, a professor at my uni told me that it is derivable from these two equations:
[tex]\frac{d \sigma^{\nu N}}{dx} = \frac{G^2 M E}{\pi} x (q(x) + \bar q (x) /3)[/tex]
[tex]\frac{d \sigma^{\bar \nu N}}{dx} = \frac{G^2 M E}{\pi} x (\bar q(x) + q (x) /3)[/tex]
Where N is your average nucleon.
I don't know if this something that should follow naturally but I feel rather lost. :-p
Think about as two equations in two unknowns: get qV(x) on one side and integrate it.
I was unclear - the two unknowns I was speaking of are q_V(x) and qbar(x). (i.e. the valence and sea distributions). Pull q_V to one side, integrate it, and G&L-S tell you it's 3.
Am I supposed to get [tex]q_V (x)[/tex] from [tex]q(x)[/tex] but keep [tex]\bar q(x)[/tex]? I tried to extract [tex]q(x)[/tex] from the system of equations, but I got a rather messy expression:
[tex]q(x) = \frac{9 \pi}{8 G^2 M E} \frac{1}{x} \left(\frac{1}{3} \frac{d \sigma^{\bar \nu N}}{dx} - \frac{d \sigma^{\nu N}}{dx}\right)[/tex]
Not least when one would be integrating this, by parts and all. ;)
Edit: I suppose a better formulation might be; how do I get [tex]F_3 ^N (x)[/tex] from the last two equations (in the first post).
qV = q - qbar.
It's probably also worth pointing out that there are many oversimplifications that go into the G&L-S sum rule. Experimentally, it's around two-and-a-half, but what was surprising wasn't that it wasn't exactly three, but that it wasn't even farther off.
I agree, but would like to point out that the gluon radiation (or any name you give to higher orders in the evolution) come in excellent agreement with the data.
Sum_GLS(3 GeV^2) = 2.50 +/- 0.018 (stat) +/- 0.078 (syst) (CCFR collaboration Fermilab, Phys Lett B331 1994 655)
compared to 2.66 +/- 0.04 expected from CTEQ95 for instance.
Does (syst) stand for systematic error? How do they estimate it?
In analogue with my last post I come to the expression for the antiquarks:
[tex]\bar q (x) = \frac{9 \pi}{8 G^2 M E} \frac{1}{x} \left(\frac{1}{3} \frac{d \sigma^{\nu N}}{dx} - \frac{d \sigma^{\bar \nu N}}{dx} \right)[/tex]
The valence quarks can be calculated by subtracting [tex]q(x)[/tex] and [tex]\bar q (x)[/tex] as Vanadium suggested:
[tex]q_V (x) = q (x) - \bar q (x) = \frac{\pi}{G^2 M E} \frac{1}{x} \frac{3}{2} \left( \frac{d \sigma^{\bar \nu N}}{dx} - \frac{d \sigma^{\nu N}}{dx}\right)[/tex]
I'm not sure how one reaches an integer answer when integrating this expression using GLS.
  • · Replies 0 ·
