How to draw 0.5 amp of current from a 10Ah battery
The discussion focuses on drawing 0.5 amps from a 24V 10Ah Li-ion battery to power four small PMDC motors. The current controller in use is rated for 3 amps and can handle voltages up to 44V. The key takeaway is that to draw the required current, the battery must be properly connected to the circuit, ensuring it is charged and has sufficient voltage. Additionally, using a current regulator is recommended to prevent overloading the motors.
  • Understanding of Li-ion battery specifications and ratings
  • Knowledge of PMDC motor operation and requirements
  • Familiarity with current regulation techniques
  • Basic electrical circuit principles
  • Research how to implement a current regulator for motor applications
  • Learn about the characteristics and limitations of Li-ion batteries
  • Explore the specifications and operation of PMDC motors
  • Investigate battery discharge rates and their impact on performance
Electrical engineers, hobbyists working with robotics, and anyone involved in designing circuits for motor control applications will benefit from this discussion.
dave226
I am planning to use a Li-ion battery running my 4 small pmdc motors rated at 24V and 0.5amps. Is 24V 10Ah battery enough to provide sufficient power to run my application? There is a current controller which is rated at 3amps and voltage upto 44V. I want to restrict the current within the limits of controller which is providing an interface with four motors.
What is the exact way to draw a required amount of current from a battery rated at 10Ah?
I tried two small power tool batteries rated at 18V nearly 1.5Ah, it run my application at first for one or two second, but later on it discharged.
Sounds like there might be something wrong with those power tool batteries (NiMH?). Anyway, you should be aware that "Ah" has nothing to do with power, but indicates the duration of the fully charged (new) battery. "The exact way to draw a required amount of current from a battery", is to simply connect it to the circuit requiring the power, and make sure that the battery is charged and has sufficient voltage. The circuit that it is connected to should determine the current. If you are concerned about overloading the motors, then you should use a current regulator.
9K
15K
  • · Replies 49 ·
