Derivative of f(z) with respect to z* does not exist
  • Thread starter Thread starter thesaruman
    Derivative
The derivative of the analytic function f(z) with respect to z* does not exist unless f(z) is a constant. This conclusion is derived using the chain rule and the relationships between the partial derivatives of f with respect to x and y. Specifically, the equation ∂f/∂x = df/dz and ∂f/∂y = i(df/dz) lead to the result that df/dz* = 0, confirming that if the derivative exists, it must equal zero. The discussion emphasizes the application of the Cauchy-Riemann equations to support this finding.
  • Understanding of complex analysis, specifically analytic functions.
  • Familiarity with the chain rule in calculus.
  • Knowledge of partial derivatives and their relationships to total derivatives.
  • Comprehension of the Cauchy-Riemann equations.
  • Study the implications of the Cauchy-Riemann equations in complex analysis.
  • Explore the properties of analytic functions and their derivatives.
  • Learn about the concept of holomorphic functions and their characteristics.
  • Investigate the relationship between complex differentiation and real-variable calculus.
Students of complex analysis, mathematicians exploring analytic functions, and educators teaching advanced calculus concepts.
thesaruman
The function f(z) is analytic. Show that the derivative of f(z) with respect to z* does not exist unless f(z) is a constant.
Hint: Use chain rule and take x = (z+z*)/2, y = (z-z*)/2.
[tex]\frac{d f}{d z*} = \frac{\partial f}{\partial x}\frac{\partial x}{\partial z*} + \frac{\partial f}{\partial y}\frac{\partial y}{\partial z*}[/tex].
Well, I used this relation, considering that the analyticity of f guarantees this. I'm not sure of this procedure, but it was the only way i figured out to use the hint of the author. Then, the result was this:
[tex]\frac{d f}{d z*} = \frac{1}{2} \left( \frac{\partial f}{\partial x} + i \frac{\partial f}{\partial x} \right)[/tex].
Next, I used another relation which I seriously doubt of:
[tex]\frac{\partial f}{\partial x} = \frac{d f}{d z} \frac{\partial z}{\partial x} = 1[/tex].
Analogously, I deduced that
[tex]\frac{\partial f}{\partial y} = \frac{d f}{d z} \frac{\partial z}{\partial y} = i[/tex].
With these results, the previous equation becomes:
[tex]\frac{d f}{d z*} = \frac{1}{2} \left( \frac{d f}{d z} - \frac{d f}{d z} \right) = 0[/tex].
This result sounds like an absurd to me, and this could be the answer by "reductio ad absurdum" but my hypothesis doesn't seem correct (or rigorous). Someone has any idea?
You mean,
[tex] \frac{d f}{d z*} = \frac{1}{2} \left( \frac{\partial f}{\partial x} + i \frac{\partial f}{\partial y} \right)[/tex]
I'm sure. The rest of your argument is correct. And yes, df/dz*=0. So if df/dz* exists, it must be zero. You can also reach the same conclusion by substituting f=u(x,y)+i*v(x,y) into that relation and using the Cauchy-Riemann equations. It is a little confusing to phrase it this way. I would say f(z*) is analytic only if f is constant.
Thanks, very much.
