Using Ampere's Law to Calculate Magnetic Field at a Point
The discussion revolves around the application of Ampere's Law to calculate the magnetic field at a specific point, particularly in scenarios where the conditions for using the law may not be straightforward. Participants explore theoretical approaches and alternative methods for determining the magnetic field.
  • One participant questions the feasibility of using Ampere's Law to calculate the magnetic field at a single point without a suitable surface where the magnetic field is constant.
  • Another participant suggests that Ampere's Law at a point relates to the Maxwell equation for curl B and implies that a differential equation must be solved for the magnetic field.
  • A participant seeks clarification on the notation B~j, which appears to be a point of confusion.
  • It is proposed that depending on the specific setup, the Biot-Savart law might be a more appropriate method to use instead of Ampere's Law, with a note on the potential difficulty in expressing current density J.
  • Further clarification on the notation is provided, indicating that the curl of B is proportional to the current density j, with a mention of unit system variations affecting the constant of proportionality.
Participants express differing views on the applicability of Ampere's Law in this context, with some suggesting alternative approaches like the Biot-Savart law. The discussion remains unresolved regarding the best method to calculate the magnetic field at a point.
There are limitations regarding the assumptions made about the magnetic field's behavior and the specific configurations of current that may affect the applicability of the discussed laws.
swraman
Is there any way to use Ampere's Law [tex]\oint_{C}\beta d\ell = \mu_{0}I[/tex] to calculate the magnetic field [tex]\beta[/tex] at a single point if there are no surfaces C such that [tex]\beta[/tex] is constant over the surface's perimeter?
Thanks
Raman
Edit: I mean solve symbolically, no estimation/splitting the integral up into discrete sums
Ampere's law at a point is the Maxwell equation for curl B~j.
You then have to solve a differential equation for B.
what is B~j?
Depending on the set-up, you may be better off using the Biot-Savart law instead. There may or may not be a way to get an expression for current density J depending on how the question is given.
swraman said:
what is B~j?
Maxwell's equation is (Curl B)=k j. The constant k is different in different systems of units.
By ~ I meant that (Curl B) was proportional to j.
Oh ok Thanks
  • · Replies 21 ·
