How can I find the domain and radius of the level curves for a given function?
  • Thread starter Thread starter jeffreylze
    Curves
The discussion revolves around finding the domain and radius of level curves for the function z = f(x,y) = -√(9 - 2x² - y²). Participants are tasked with sketching the level curves and understanding the implications of the function's structure on these curves.
  • Participants discuss substituting a constant z = c into the function and rearranging the equation to identify the resulting shape as an ellipse. Questions arise regarding the domain for c and the implications of the derived equation 9 - c² = 2x² + y².
There is an ongoing exploration of the conditions under which the derived values are valid. Some participants have provided hints and guidance on how to approach the problem, particularly regarding the values that a can take and the implications for c. Multiple interpretations of the conditions are being discussed, particularly around the relationship between c and its square.
Participants note the importance of understanding the restrictions on c, particularly that c must be non-positive due to the nature of the function. There is also mention of the symmetry of the ellipse and the need to consider the intersection points with the axes.
jeffreylze
z=f(x,y)= -[tex]\sqrt{9-2x^2-y^2}[/tex]
Sketch the level curves for f(x,y)
I am really poor at this. I let z = c (a constant) . Substituting c into the equation and rearranging it, I got this 9-c[tex]^{2}[/tex]=2x[tex]^{2}[/tex]+y[tex]^{2}[/tex]
From this, I know i will get a ellipse. But I am stuck here. How do I find the domain for c and the radius? Some hints will be helpful. Thanks
Hi jeffreylze! :smile:
Hint: first, put 9 - c2 = a, so it's 2x2 + y2 = a …
i] what values can a have?
ii] yes, it's an ellipse, and obviously its centre is at the origin, so just find the points where it intersects the x and y axes. :smile:
i) Since ellipse has a general equation, (x-h)^2/a^2 + (y-k)^2/b^2 = 1, hence the a you were referring to would have the values >= 0 ? I don't know, I am quite confused.
No, a2 must be non-negative but a itself can be any (non-zero) number. Bacause of the symmetry, it really doesn't matter.
Hence, 9-c^2 >= 0 ?
jeffreylze said:
Hence, 9-c^2 >= 0 ?
Nooo … 9 - c2 = a,
and the only restriction is that c2 ≥ 0 …
so a … ? :smile:
so a[tex]\leq[/tex]9 ? Am i right this time?
Yup! :biggrin:
oops … sorry … i forgot what this was all about :redface: … i forgot about the √(9 - 2x2 + y2), so your first answer, a ≥ 0, is also correct: 0 ≤ a ≤ 9.
And now … find the points where it intersects the x and y axes. :smile:
but the i still couldn't get the answer -3 ≤ c ≤ 0. This is what i did, for 0 ≤ a ≤ 9, I subbed a= 9 - c^2 into it to get 0 ≤ 9 - c^2 ≤ 9 , rearranged and i got 0≤|c|≤3 . Where did i go wrong?
Well, basically, you're right,
but you dropped a condition when you started to use c2 instead of c …
when you go back from c2 to c, you have to remember that c to c2 is single-valued, but c2 to c is double-valued, and you have to select the right square-root (of c2) …
in this case, the original equation for f specified the negative square-root …
so you combine the condition c ≤ 0 with your result 0≤|c|≤3 to give …
da-daa! … -3 ≤ c ≤ 0. :smile:
(actually, it would have been a lot quicker, and just as accurate, to say, just by looking, that the square-root of nine-minus-something-positive must be between 0 and 3 :wink:)
