Thread Closed
net electric force on neg charge next to a pos charge, inbetween a elec field
Share Thread
Jan22-09, 09:43 PM   #1
Two point charges, Q1 = -6.9 µC and Q2 = 1.1 µC are located between two oppositely charged parallel plates, as shown in Fig. 16-65. The two charges are separated by a distance of x = 0.38 m. Assume that the electric field produced by the charged plates is uniform and equal to E = 72000 N/C. Calculate the net electrostatic force on Q1 and give its direction.
2. Relevant equations
Felectric = K (Q1 * Q2) / (r^2)
Felectric = qE
3. The attempt at a solution
I'm unsure how to approach from this point. I found the force between the two charges.
F = (9x10^9) [(6.9 x 10^-6)(1.1 x 10^-6) / (.38 ^2)] = .4730609418 N
Then i figured that because it is a constant electric field I could use this equation.
Since the problem states it wants the net charge on Q1, i used that charge for this equation.
F = qE = (6.9 x 10^-6)(72000) = .4968 N
Now I'm trying to find the netforce and whatever I put in seems to be wrong. Electric fields flow from positive to negative so I figured adding these two values would be the correct answer. The force of attraction to Q2 to the right and the force of the electric field to the right. What am I doing wrong?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jan23-09, 10:53 AM   #2
Quote by hopeless123 View Post
Felectric = qE
You have the right equations and the right idea - E fields can be summed linearly - however, Q1 has -ve charge and so will be attracted to the +ve plate, and also to (+vely charged) Q2. So the forces are in opposite directions and one should subtract them to find the net force.
Thread Closed
Similar discussions for: net electric force on neg charge next to a pos charge, inbetween a elec field
Thread Forum Replies
electric field of a line charge and point charge Introductory Physics Homework 14
Net Electrostatic Force on a neg charge next to a pos charge inbetween a field Introductory Physics Homework 2
HELP!!! Charge for an electric field Advanced Physics Homework 3
Electric field due to arc of charge Introductory Physics Homework 6
Electric field/charge Introductory Physics Homework 1
