| Thread Closed |
What kind of motor do you think i need? |
Share Thread | Thread Tools |
| Jan23-09, 04:38 AM | #1 |
hi,
I'm doing an experiment, in realisation of which i need to move a steel plate up and down. Please consider the following constraints faced by me: -The plate would rise to 12mm at most. -The speed should be such that it rises 12mm in around half a second. -I want to be able to stop the plate anywhere between 0-12mm. -Variation of the speed may also be needed. -The plate will be exposed to high pressurefield above, so will tend to come down. -I have only 75mm(L)*175mm(W)*25mm(H) space to accommodate the lifting mechanism. -I can also mount the motor outside the above mentioned cavity, but the motor diameter less than 30mm is preferred. After considering all the above mentioned constraints, i've thought of getting a miniature rack and pinion system manufactured. But the driving motor is still not finalized and i'm facing a problem in it. Initially i thought of using a geared dc motor but then i won't be able to stop it at the precise positions (4mm say). Servos can definitely be used but the speed control is a problem. Stepper motor seems a good choice but i haven't got much experience working with them. So, please help me choose a good motor or a new mechanism. Thank you in anticipation. Abhishek. |
| Jan23-09, 10:28 AM | #2 |
how about using a threaded shaft DC motor(make a small coupling) & a nut as the plate? It sure would give high reduction, space requirement is also isnt much, can be quick. though i dunno how well it would respond to speed requirement.
| Jan23-09, 03:55 PM | #3 |
Hi Aviator,
Judging from your speed requirements, 12mm in 0.5sec, which translates into quite a steep acceleration profile, i suspect a power-screw setup will be too slow. I would recommend looking at a linear drive instead. It will be more expensive, but you can get really fast dynamic response as well as integrated position feedback. Check out these sites: - http://www.faulhaber-group.com/servl...2/i428419.html - http://www.copleycontrols.com/Motion...otors/sta.html I used one of the ones from copley, STA1104 i think, for a project recently instead of building a crank/con.rod system hooked up to a motor. Keep in mind you need to buy the drive electronics as well. For their smallest servoTube i paid about 1000chf + 600chf for the control box. (1chf ~ 0.9USD) But compared to making anything custom this was a bargain. The drive comes with software and you can drive it from your PC or using an oscilloscope. You could also easily integrate it's control into a Labview application if it's part of a bigger experiment. I would suggest to try and refine your speed, acceleration, load and space/mounting requirements and make a request to both of these companies. I do this all the time when i'm looking for a component, usually get tons of good responses! Finally, you will need a linear coupling to connect the linear drive to your load. Ask in your request for a recommendation on this as well. Hope this helps and good luck! |
| Jan24-09, 02:55 AM | #4 |
http://www.flickr.com/photos/3371122...65139/sizes/o/
this is a possible solution. I dont find a suitable motor. i think steppers might work, but circuit is the problem. I dont have any exposure of microcontroller programming. Well, thanks coreyh. Althought the solution you proposed is good, i'm not in a state to afford the same.
| Thread Closed |
| Thread Tools | |
Similar Threads for: What kind of motor do you think i need?
| what kind of job can i get with | Academic Guidance | 3 | ||
| What kind of connection is there betweeen Amp Turns and Motor Torque Constant? | Electrical Engineering | 0 | ||
| What kind of job can get with........ | Academic Guidance | 6 | ||
| What kind of a bomb? answer:the exploding kind. | Special & General Relativity | 9 | ||
| PDE kind | Differential Equations | 9 | ||
