Understanding Velocity and Acceleration in Uniform Circular Motion
In uniform circular motion, the velocity of an object is always tangential to the path, while the acceleration is centripetal, directed towards the center of the circular path. The position vector is defined as \vec{r}=Rcos(\omega t)\hat{x}+Rsin(\omega t)\hat{y}, where \omega is the angular frequency, t is time, and R is the radius. The velocity is calculated as \vec{\dot{r}}=-\omega Rsin(\omega t)\hat{x}+\omega Rcos(\omega t)\hat{y}, and the acceleration as \vec{\ddot{r}}=-\omega^{2}\vec{r}, indicating that acceleration has a magnitude of \frac{v^{2}}{R} and is directed towards the center of the circle.
  • Understanding of vector calculus
  • Familiarity with angular frequency and its relation to circular motion
  • Knowledge of derivatives and their application in physics
  • Basic concepts of centripetal force and motion
  • Study the relationship between angular velocity and linear velocity in circular motion
  • Learn about the derivation of centripetal acceleration and its applications
  • Explore the effects of varying radius on velocity and acceleration in circular motion
  • Investigate real-world applications of uniform circular motion in engineering and physics
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in the principles of motion in circular paths.
physicsman7
how does velocity and acceleration change in circular moton
I know when a object is circular motion the velocity is tangential to the motion also, acceleration centripetal, sum of the forces which points to a center seeking force
In Uniform Circular Motion the position vector can be expressed as
[tex]\vec{r}=Rcos(\omega t)\hat{x}+Rsin(\omega t)\hat{y}[/tex]
where omega is the frequency of oscillation, t is time , and R is the radius of the circle.
We calculate velocity and acceleration by taking first and second derivatives with respect to time.
[tex]\vec{\dot{r}}=-\omega Rsin(\omega t)\hat{x}+\omega Rcos(\omega t)\hat{y}[/tex]
[tex]\vec{\ddot{r}}=-\omega ^{2} Rcos(\omega t)\hat{x}-\omega ^{2}Rsin(\omega t)\hat{y}=-\omega ^{2}\vec{r}[/tex]
Also, [tex]R\omega = v[/tex] where v is the tangential velocity (To show this use [tex]Rd\theta =dS[/tex] where dS is an infinitesimal tangential distance and divide both sides by [tex]dt[/tex]) so
[tex]\vec{\ddot{r}}=-\frac{v^{2}}{R^{2}}\vec{r}=-\frac{v^{2}}{R^{2}}R\hat{r}=-\frac{v^{2}}{R}\hat{r}[/tex]
So the acceleration is anti parallel to the radius vector (ie. towards the center of the circle) and has a magnitude of [tex]\frac{v^{2}}{R}[/tex]
thanks kind of get it
