| Thread Closed |
How far apart are two stars |
Share Thread | Thread Tools |
| Feb7-09, 08:56 PM | #1 |
Two stars 18 light-years away are barely resolved by a 68 -cm (mirror diameter) telescope. How far apart are the stars? Assume \lambda = 540 <units>nm</units> and that the resolution is limited by diffraction. Express your answer using two significant figures. 2. Relevant equations Theta=(1.22 lambda)/diameter of the lense 9.4605284 × 10^15 meters 3. The attempt at a solution I have no clue how to do this. I plugged the give info into the equation and got theta to equal 9.6882352941176470588235294117647e-7 then i just plugged this into the Pythagorean equation to get 559491313771834207552834.45286104 |
| Feb7-09, 09:24 PM | #2 |
Recognitions:
Roughly from similair triangles:
lamba/D = separation/distance The angle between the stars is 1.22lambda/D so you can work out this angle (remember is answer in radians) then you have the angle between two stars a distance away so getting the distance between them is easy. Since the angles are small you can use the apprx theta = sin theta (in radians) |
| Feb7-09, 09:43 PM | #3 |
I have worked it out both ways and both of the answers i got were wrong
| Feb8-09, 10:41 AM | #4 |
Remember, as mgb_phys stated, Rayleigh's Criterion expresses the angular distance in radians.
If you're still getting the incorrect answer I suggest you explicitly post how you're calculating the distance. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How far apart are two stars
| strange stars and neutron stars | General Astronomy | 6 | ||
| Pop 111 stars | General Astronomy | 4 | ||
| stars and gas | General Astronomy | 4 | ||
| Question on binary stars & binary stars | Introductory Physics Homework | 1 | ||
