Thread Closed
Help in Split step fourier method
Share Thread Thread Tools
Feb11-09, 11:01 AM   #1
Hello all,
I have short question at the end , but i wil gve short background.
The subject is regarding the split step fourier method (SSFM) adn i will be gratefull if someone who know the method can help.
i have the set of 2 equations:
Utt=Uzz-a*U+i*P-(P^2)*U
Pt=-i*P-(P^2)*U
where: P, U are the function need to be find P(z,t) U(z,t)
i = sqrt(-1) a=constant
I try to do the split step fourier method (SSFM) on this set, the problem is that the first equation derivative are from order 2, and in all the examples i saw it was from order 1.
I try to seperate to linear part and nonlinear part:
for the first equation:
U_linear_tt=Uzz-a*U
U_nonlinear_tt= i*P-(P^2)*U
and for the second equation:
P_linear_t=-i*P
P_nonlinear_t=-(P^2)*U
now when i try to do the fourier transform at the linear part, for the U function, it is problem because the derivative is second order.
if it was from first order the fourier transform for the linear part becomes:
Fourier_U_linear(t+dt,z)=exp{(-w^2-a)*dt}
how do i modified it on my case when the derivative is second order ?
thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May24-09, 06:57 AM   #2
Thread Closed
Thread Tools
Similar Threads for: Help in Split step fourier method
Thread Forum Replies
Split Step Fourier Method Differential Equations 1
Differential Equation Problem_Solution step by step Calculus & Beyond Homework 1
Limitation of Split-Step Fourier method Differential Equations 1
Limitation of Split-Step Fourier Method General Physics 0
Step by Step rearranging with square roots... General Math 7
