Forward Biasing a Diode: Explained
  • Thread starter Thread starter unseensoul
    Diode
unseensoul
There are a lot of resources out there which mention that when a diode is forward biased the majority carriers at the n-type material will move to the p-type material "through" the holes therefore the holes will move from the p-type region to the n-type region.
However, this doesn't make any sense to me at all...
As the majority carriers in the n-type region are at an excited state they are free to move about the material. Therefore when the diode is forward biased (assuming that external voltage is higher than barrier potential) the majority carriers (electrons) in the n-type region would move along the p-type material without recombining with the holes.
However, the holes would still move in opposite direction not due to the n-type's majority carriers but due to the neighbour valence electrons (which aren't in an excited state) being pushed due to the external voltage.
This explanation makes much more sense to me than the first one although I'm not sure whether that's what real happens.
I'd like to "hear" your suggestions/thoughts...
Edit:
http://img21.imageshack.us/img21/9639/84077772ht7.jpg" illustrates what I'm talking about; Notice the hole in the middle moving to the right plus the free electron at the top moving in opposite direction.
Ok, I'll make the question in this way...
Would there be conduction if I joined a n-type material (extrinsic) with an intrinsic silicon material and connected an external voltage across both ends (neglecting e-h pair generation)?
In a forward-biased p-n junction, electrons from the depletion region are pushed further into the p material where they quickly recombine with holes.
As I understand it, this creates a deficit of holes, the majority carrier, in the p material. Additional holes are available and abundant in the p material, and move into "fill in" the deficit. Additional holes keep moving in from the wire contact (actually, the wire keeps removing electrons to create additional holes in the p material.)
The net flow of holes in most of the p material, and the flow of electrons from the depletion region into a short distance of the p material, maintain the same net current throughout the material.
An analogous process occurs in the n material.
Hope that is clear enough. I have always struggled to understand this on a microscopic scale, and have pretty much resigned myself to accepting the v-i curve for what it is.
Hmmm, don't know if this is done in practice. I know that sometimes a thin intrinsic-material layer is used between the p and n regions, I think to lower capacitance in for example p-i-n photodiodes.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
