What is the Kinetic Energy Formula for a Satellite Orbiting Earth?
The discussion revolves around calculating the kinetic energy of a satellite orbiting Earth, specifically a 180-kg satellite with a given orbital period. Participants are exploring the relevant equations and relationships between gravitational force, centripetal acceleration, and orbital mechanics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between period and angular velocity, and how to derive the radius of the satellite's orbit. There are attempts to equate centripetal acceleration with gravitational acceleration to find unknowns. Some express confusion about the equations and the overall approach to the problem.
The discussion is active, with participants offering various insights and suggestions for approaching the problem. Some have proposed methods to derive the radius and velocity needed for calculating kinetic energy, while others express frustration with the complexity and time constraints of the question.
Participants note that the radius of the satellite's orbit is not explicitly provided in the problem statement, which adds to the challenge of finding a solution. The time constraint for answering multiple-choice questions is also mentioned as a factor in the discussion.
skiing4free
What is the Kinetic energy of a 180-kg satellite which circles the Earth (radius=6.4x10^6m, mass=6.0x10^24kg) with a period of 8.0 h?
a)2.2x10^9J
b)2.0x10^9J
c)1.8x10^9J
d)2.4x10^9J
e)3.6x10^9J
Ep= GM1M2/r
Ek=.5Mv^2
Ac=(4[tex]\pi[/tex]^2r)/T^2
v=-[tex]\omega[/tex]^2r
Ep=Ek
The radius that the satellite is orbiting is not given only Earth's radius, i tried to use ratios but this cannot work as the satellite is moving much faster than earth. Then i tried a guess and check method with the given options trying to cross check the speed. Eventually i got an answer of 1.8x10^9J which is correct. There must be a better method for calculating the radius of the satellite?
not sure about your equations but hopefully this should help
Think about how the period & angular velocity are related
Then think about the force at work, ie the acceleration due to gravity causes the circular motion... can you equate something here to work toward a radius...
its sounds like an easy question and probably is but i keep getting confused with it, in answer to lanedance question, centripetal acceleration=angular velocity squared*radius
[tex]\omega[/tex]=[tex]\Delta[/tex][tex]\theta[/tex]/[tex]\Delta[/tex]T
maybe its just me but i keep going round in circles...
(terrible pun i know)
so you have the angular velocity as you know it does 1 full revolution in 8hrs, centripetal accelaration equation looks good...
the key is the centripetal acceleration is the acceleration caused by gravity, so equate both terms and see what unknowns are left...
they told you time it takes for 1 rev, so if you know the distance [ circumference] and the time, you can find V, so just 1/2 mv^2
the orbit radius is not given in the question
hm, then I guess use Gm(p)m(s)/r^2 = m(s)v^2/r
you know G, the gravitational constant, you know the mass of the Earth and satelite..
theen, since you don't know v OR r, you can use v = d/t, so
Gmp/r = (r/t)^2, solve for r. once you know r, find v, then KE.
OK i get where you're coming from, pity is that these multiple choice questions have to be answered in 1.5mins each or else u don't finish the paper in time, and this was an easy question from the extended paper grrrrr
  • · Replies 39 ·
  • · Replies 21 ·
