Thread Closed
angular separation help here :p
Share Thread Thread Tools
Feb28-09, 06:11 PM   #1
the question is:calculate angular seperation between 1st order red and 1st order violet.data given:theta=22,d=1.20x10^-6
2. Relevant equations
theta=a/D ( is that the 1?)
and if it is dn what would the function be hmm tan? (isnt it related to stellar distances)
3. The attempt at a solution
hmm not sure
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Feb28-09, 10:03 PM   #2
Mentor
More information is needed.
What is this question in reference to? A prism ? Diffraction by a single or double slit ? Diffraction grating ? Something else?
Also, what are the wavelengths for "red" and "violet"?
EDIT:
Click on the words "diffraction", "double slit", or "diffraction grating" above for equations.
Mar1-09, 04:56 AM   #3
b)white light containing a spread of wavelengths ranging from 450nm(Violet) to 700nm(Red) is incident normally on a diffraction grating.it is observed that the first-order violet line occurs at angle22.
1)calculate d.
2)calculate angular separation between first order red and first order violet.
3)show that 2nd spectrum of violet(7oo)nm will not be present.
4)state what would be seen at angle=0
well from above the question i solved d where i mentioned above ,question 3 and 4 are simple where i need to prove thru the formula but part 2 is where im confused.
Mar1-09, 09:05 AM   #4
Mentor
For a diffraction grating, use the same equation you gave in your other question:
Quote by ibysaiyan View Post
n(lambda)=dsin(theta)
You can use the information about the violet line for part (1). After that, get the angle for the red line to help with part (2).
Mar1-09, 10:08 AM   #5
Quote by Redbelly98 View Post
so the angle which i get from part(2) would give me the angle separation ?
Mar1-09, 10:34 AM   #6
Mentor
Not quite. You need to find the separation (i.e. the difference) between that angle, and the angle of the 1st-order violet line.
Mar1-09, 10:46 AM   #7
ah,k was thinking of that
Mar3-09, 04:05 PM   #8
tyvm =)
Thread Closed
Thread Tools
Similar Threads for: angular separation help here :p
Thread Forum Replies
Are angular displacement, angular velocity, and angular acceleration, vectors? Classical Physics 5
Separation of variables and the separation constant Calculus & Beyond Homework 4
Separation of Variables Calculus & Beyond Homework 1
Angular Separation Between Two Stars Introductory Physics Homework 1
isomer separation Chemistry 3
