Linear algebra, point of intersection
The discussion revolves around finding the point of intersection between a line defined parametrically and a plane represented by a linear equation. The line is given by the equations x=3+t, y=2-4t, and z=-5+11t, while the plane is described by the equation 12x+10y-4z=48.
  • Participants discuss the nature of the intersection between the line and the plane, questioning the correct form of the plane's equation. There is an exploration of substituting the line's parametric equations into the plane's equation to find the intersection point.
Some participants have provided guidance on how to approach the problem, suggesting substitution of the line's equations into the plane's equation. There is a recognition of differing interpretations regarding the plane's equation, with some participants noting the implications of the constants involved.
Participants express varying levels of familiarity with solving systems of linear equations, with some indicating they are beginners. There is mention of a specific value related to the plane's equation that may influence the discussion.
cleopatra
1) x=3+t
y=2-4t
z=-5+11t
2)12x+10y-4z
Find the point where these two lines intersect.
please help!
I mean, where the line in 1 and plan in 2 intersect
cleopatra said:
1) x=3+t
y=2-4t
z=-5+11t
2)12x+10y-4z
Do you mean 12x+10y-4z=0?
Also, please show that you have https://www.physicsforums.com/showthread.php?t=94383".
=48
but I don´t think that matters
cleopatra said:
=48
It does matter. The equation 12x+10y-4z=48 defines a different (but parallel) plane then the equation 12x+10y-4z=0. For example the second one passes through the origin while the first does not (to see this, just check if x=0,y=0,z=0 satisfies the equation).
okey thanks
but do you know how to solve it?
cleopatra said:
okey thanks
This is a system of linear equations (4 equations, 4 unknowns). I am almost sure you have solved systems of linear equations before, for example when intersecting two lines in the plane:
2x+y=1
x-3y=0
How did you do that? Hint: Substitution. Your problem can be solved in a similar way.
I really haven´t solved anything like this. I´m a beginner.
I just really need a good teacher to show me how to do this.
Can you? Or if you can´t solve it, can anybody else?
And, the answer of the plane is =46, not 48.
you have an equation for a plane
ax + by + cz = d
a,b,c,d constants
and a line (x(t),y(t),z(t))
what happens when we are on both the plane & line? bothe equations will be solved
substitute your line components (x(t),y(t),z(t)) into the equation of the plane & solve for t
this give the point on the line in terms on twhere the plane & line intersect
Put your expressions for x, y and z in terms of t into the equation of the plane. Then solve for t.
Anyone who can show me some equations?
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 28 ·
