Why is there a doubt in Coulomb's formula?
  • Thread starter Thread starter nikromancer
    Doubt Formula
Coulomb's formula, expressed as F = k(q1*q2/d^2), defines the force between two electrically charged bodies, where k is 9*10^9 Nm^2/C^2. The discussion clarifies that the formula provides the magnitude of the force, not its direction. The force is repulsive for like charges and attractive for unlike charges, determined by the sign of the product q1*q2. The vector form of Coulomb's law is essential for understanding the directionality of the force, represented as F = K(q1q2/r^2)−hat{r}, where hat{r} indicates the direction from one charge to the other.
  • Understanding of Coulomb's law and its mathematical representation
  • Familiarity with vector notation in physics
  • Basic knowledge of electric charge interactions
  • Concept of force directionality and magnitude
  • Study the vector representation of forces in electromagnetism
  • Learn about the implications of charge signs in Coulomb's law
  • Explore the concept of electric fields and their relation to charge interactions
  • Investigate the applications of Coulomb's law in real-world scenarios
Students of physics, educators teaching electromagnetism, and anyone interested in understanding electric charge interactions and Coulomb's law.
nikromancer
Coulomb's formula states that the force of attraction between two electrically charged bodies is k(q1*q2/d^2), where k is 9*10^9 Nm^2/C^2. However, I have a doubt regarding this.
We know that like charges repel and unlike charges attract. Let us take the case of like charges first. If both q1 and q2 are like charges, the value of q1*q2 will be positive. As d and k are also positive, the force of attraction will also be positive. However, this means that like charges ATTRACT each other rather than repel. Similarly, if q1 and q2 are unlike charges, then the force of attraction will be negative and this means that unlike charges repel and like charges attract. But this isn't true.
So, shouldn't the formula be F= -k(q1*q2/d^2) or |F|=k(|q1*q2|/d^2)?? Please clarify.
The formula you give only gives the magnitude of the force, not the direction.
The full (vector) form giving the force on charge 1 is
[tex]k {q_1q_2 \over r^2}\mathbf{\hat{r}}_{21}[/tex]
where [itex]\mathbf{\hat{r}}_{21}[/itex] is the vector pointing from charge 2 to charge 1. So if the charges are like, then the force vector will point along this vector, meaning it is repulsive.
You shouldn't interpret F as the force of attraction. The F in Coulomb's law is simply THE force charge 1 exerts on charge 2. If it is negative, it will be attractive (in the direction to make the distance between chages decrease) and if it is positive, it will be repulsive.
The notation you are using can confuse whether the force is attractive or not. The unambiguous way of writing coulomb's law is with vector notation (3 dimensions):
The force charge 1 exerts on charge 2 is
[tex]\vec F = K \frac{q_1q_2}{r^2}\hat r[/tex]
where [itex]\hat r[/itex] is the unit vector from q1 to q2 (i.e. [itex]\vec r_2-\vec r_1[/itex]).
In one dimension, you can work with signs, but you have to take care with the directions.
F = K(q_1q_2/d^3) * (x2-x1), where (x2-x1) is the signed distance x2-x1. So if x2>x1, then x2-x_1=d and the force is Kq_1q_2/d^2. This is positive for like charges, to the force is such that x_2 tends to increase (repellant). Figure out the other cases yourself.
