Coil Moving through a Magnetic Field
The problem involves a rectangular coil moving through a magnetic field, with specific parameters such as resistance, dimensions, and velocity. The goal is to determine the force required to maintain the coil's velocity after it enters the magnetic field.
  • Participants discuss the calculation of force using the relationship F = IwB and the implications of the coil's motion through the magnetic field. There are questions about the contributions to current and voltage in the context of the coil's movement.
Some participants are exploring the relationships between voltage, current, and force, while others are questioning the assumptions made in the walkthrough. There is an acknowledgment of confusion regarding the application of the equations and the contributions to the current.
Participants note that the walkthrough suggests certain equations are correct, but there is uncertainty about how to apply them correctly. There is also mention of the coil just entering the magnetic field, which may affect the calculations.
Lanc1988
At t=0, a rectangular coil of resistance R = 2 ohms and dimensions w = 3 cm and L = 8 cm enters a region of constant magnetic field B = 1.6 T directed into the screen as shown. The length of the region containing the magnetic field is LB = 15 cm. The coil is observed to move at constant velocity v = 5 cm/s. What is the force required at time t = 0.8 sec to maintain this velocity?
F(0.8 sec) = ?? N
This problem has a walkthrough to help me solve it, however I have reached the end of the walkthrough and tried using the equation but it isn't working for me.
I find out the following in the walkthrough:
the change in flux (dF/dt) through the loop is 1.6*0.03*0.05
the current can be calculated using V=IR
and finally F = IwB
so for the answer I try: (.05/2)*.03*1.6 but it keeps saying that it is wrong.
Hi there,
Have you taken into account there are two parts of the wire perpendicular tot he B-field?
As i go through the walkthrough it tells me that 2 of the wires cancel each other out and I am only left with needing to calculate the force on the wire of length w
My mistake, I didn't realize it only just entered the field. Try working this through algebraicaly first to obtain a final expresion for F, then put the numbers in. I think you should have a couple of squared quantities in there somewhere.
but they tell me in the walkthrough that all of those equations are correct.. at the end I am told that F = IwB and that I now have enough information to solve the equation for the final answer so I don't understand why it keeps telling me that my answer is wrong.
Yes, F=IwB. What does I=?
According to this you have said that: current=velocity/resistance. This is not true in any circumstance.
they told me to use the equation V=IR so the current should be equal to V/R.. how am i suppose to figure out what the current is then?
The flux through the coil that you calculated in your first post is equal to the emf generated in the coil by the motion through the b field.
The V in the expression of V=IR is always the voltage.
In this situation the only voltage contribution is from the emf generated in the wire, which you have already calculated.
i see now.. when i saw V=IR without thinking about it i just put the v for the velocity.. it all makes sense now, thanks for your help.
Your welcome. Did it come out right in the end?
