How Much Can a Fireman Weigh to Safely Climb a Ladder Leaning at 45 Degrees?
  • Thread starter Thread starter Rha1828
    Torque
The maximum mass a fireman can safely climb on a 5m uniform ladder, which has a mass of 15 kg and leans at a 45-degree angle against a wall capable of supporting a maximum force of 500 N, is calculated to be approximately 86 kg. The calculation involves balancing torques around the base of the ladder, using the equation for torque (Force x Perpendicular distance). The correct approach requires considering the weight of the ladder and the fireman together, ensuring that the sum of torques equals zero.
  • Understanding of torque and moments in physics
  • Basic knowledge of forces and equilibrium
  • Familiarity with trigonometric functions, particularly cosine
  • Ability to perform unit conversions and calculations involving mass and weight
  • Study the principles of static equilibrium in physics
  • Learn about torque calculations and their applications
  • Explore the concept of center of mass in uniform objects
  • Investigate the effects of different angles on ladder stability
Physics students, engineers, safety professionals, and anyone interested in understanding the mechanics of ladders and forces acting on inclined structures.
Rha1828
A uniform ladder of a length 5m and a mass 15 kg leans against a wall, making a 45 degree angle with the ground. The wall is capable of supporting a maximum of 500 N.
A fireman must climb the ladder to it's midpoint, what is the max mass that the fireman can be without collapsing the wall.Ok...So I know that for a uniform problem we know that this means that the Center of Mass will be halfway along the lengh of the board.
Again since this is a center of mass problem the sum of the torques must equal zero.
Et=0
I assumed that I would need to take the (max force)(cos 45) + (Weight of ladder)(distance of ladder) then divide that by the (total distance of the ladder)The answer should be 86.95kg
But I got..
(500N)cos45 + (15kg)(5m)
= 353.33N + 75 kg.m
= 428.33 N.kg.m / 5.0m = 85.66 = 86 kg
I am doing something wrong. I am not able to cancel out some of my units. Its seems like a simple mistake but any advice would help!
Thanks!
Force X Perpendicular distance = Torque.
Net torque = 0
500 X 5 cos45 = (15+m) g X 2.5 cos 45
m = (1000/9.8) - 15 = 87 Kg
Welcome to PF!
Hi Rha1828! Welcome to PF! :smile:
I don't understand this at all :confused:
you should be taking moments (torques) about the base of the ladder …
that's ∑(force x perpendicular distance)
try again :smile:
sArGe99, on this forum, please don't try to give complete answers​
15K
